Question about Toro Garden
Handle to raise back wheels broke off . can you buy a handle to raise and lower rear wheels
    Top Expert:
  • Toro Master
  • 10,875 Answers
Posted on Apr 10, 2015
  • 125 Answers
YES, At the lawn mower shop
How to remove the spare tire on a 01 chevy Tahoe all wheel drive
if it is under the vehicle there is a winch that lifts it into place many have a hole in rear of vehicle that you use jack handle to lower /raise the tire into place .
Sep 27, 2017 | Cars & Trucks
My sunroof is stuck with the back raised, the feature never worked it would slide open but the back would not raise or lower the other day it opened on its own and im now unable to close it.
Somewhere at the front or rear inside, there should be a removable plug. In the toolbox there would have been a small crank handle.
Dec 31, 2016 | Audi Cars & Trucks
Matrix scooter
check brakes. raise front wheel and spin should spin freely. if so lower front wheel back to ground and raise rear wheel. turn wheel by hand and listen for brake drag/binding should turn easy. loosen axle nut see if that helps . loosen nut no more than half a turn.
Jul 14, 2013 | Motorcycles
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Is there any way to lowed my 1986 cavalcade?
Easy answer, NO. But there are 3 things you can do but they are not easy.
1, if you take to the seat and lower the foam in the seat, you can make it lower.
2, you can lower the front froks by about one inch by removing the handlebar clamp cover, seat, false tank, steering head vents and loosening the 2 clamps on each fork, one on each tripple clamp, rotating the forks as you slide them up about one inch max, do both and make sure they are raised the same amount. This method causes a slight change to the Rake/Trail and can effect the handling.
3, You can get shorter rear shocks, as long as the new oes do not cause the rear wheel to rub on the inside of the wheel arch.
Join the worldwide Yahoo email group for these bikes via www.suzukicavalcade.com for further assistance.
Sep 26, 2010 | 1986 Suzuki GV 1400 Cavalcade GT
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
How to raise the handle bar in huffy 14" princess bicycle??
The silver bolt on the neck behind the handlebars. Losen it off a few turns, and the entire stem can be raised and lowered. Be sure not to raise it too much, should be a minimum mark, or else leave a good inch or two still in the frame, and tighten it back up. Make sure it's aligned with the front wheel though!
Jun 26, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
Can't get the spare tire off from underneath the vehicle
Under the back seat, you will find a jack, the jack-handle serves as a turning device to lower the rear wheel. In the rear bumper section of the car you will find a hole to put this in. The rod will catch in a link that you can turn, which raises and lowers the wheel. All of this should be in the manual.
Mar 15, 2009 | 1997 Nissan Pathfinder
Lowering/raising the spare tire
there should be a crank handle under the hood and an access hole just above rear bumper
Jun 28, 2008 | 1999 Mercury Mountaineer
'87 auto
There is this pull handle.
It might be locked into place, so you lift it up and pull it out i believe
then you change your steering wheel position then you push the pull handle back in
and push it down to lock it in.
Jun 09, 2008 | 1987 Honda Accord
Garden Logo
181 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
