In charging freon How many psi should be charge on 1HP aircon
  • 323 Answers
SOURCE: Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
Posted on May 22, 2009
SOURCE: it takes more then 30 minutes to drop 1 degree
Air filter needs replaced, if the air is low flow but cool out of registers.
Need to find the leak in freon line if air is not cool.
Clean outside unit if either one applies.
Posted on Jun 05, 2009
jasperoni
  • 203 Answers
SOURCE: 2001 Mercedes S500. Air conditioner won't blow cold even though
I think that this might help you. The a/c compressor is a continuos running type there is no clutch. It has a wobble plate internally wich changes the piston stroke. Screw the genises machine-it is probably only reading a partial on the climate control module. see if you can find the self diagnoses diagram either from the factory or if you have all data. you can pull the codes right from the unit itself and they will be accurate. If you can,t pull codes see if you can get an actual value of the sensors in the a/c unit. You should be able to pull that up as well if not try the genisis. Look very closely at you evaporater sensers(left and right) you will probably see a -40 degrees-that is the sensor default input reading when the sensor goes open. That sensor is used to moniter the wobble plate position of the compressor.
Posted on Jun 30, 2009
  • 587 Answers
SOURCE: my motor compressor thrifts every 5 mins.
If you have a low pressure switch on your air conditioner it's opening and closing, because you don't have enough refrigerant in the system or it's cycling on the thermal overload in the compressor because it's getting hot.
You need to charge your system to approximately 12° to 15° superheat not by pressure.
Posted on Mar 26, 2010
  • 1169 Answers
SOURCE: Delfield 6000xl: what is the 404a freon charge?
http://www.delfield.com/?xhtml=xhtml/del/us/en/general/partsandservice/archivemanuals.html&xsl=minisite.xsl
this is for their web site. It has all the manuals and charging tables. There is no 6000xl. Need exact model number as the amount varies.
Hope this helps
Posted on Apr 01, 2010
Air conditioner blows hot air
For this problem, I would like to suggest you take help from any of the reliable servicing and repairing team.
I always prefer aircon service for any problem related to my air conditioner, as they are specialized in air conditioning servicing and repair.
Ranging from simple Aircon servicing to Aircon overhaul, they offer all kinds of services and solutions that you need in order to ensure the maximum efficiency of your unit. Also, they take reasonable charges for their various services.
Jun 27, 2016 | 1998 Lincoln Navigator
What is the Freon capacity on my 2002 Saturn SC1. It has a 1.9 liters engine, 4 cylinders.
THE ACTUAL FREON CAPACITY IS UNIMPORTANT. WHAT IS IMPORTANT IS THE PRESSURES WHEN THE SYSTEM IS RUNNING. THE LOW SIDE SHOULD BE 25-35 PSI, THE HIGH SIDE APPROX 250 PSI. THE HIGHER THE AMBIENT TEMP, THE HIGHER THE HI SIDE PRESURE. USE PROPER TOOLS TO CORRECTLY EVACUATE AND CHARGE THE SYSTEM. AVOID OVERCHARGING AS TOO MUCH FREON IS WORSE THAN NOT ENOUGH.
Apr 01, 2013 | Cars & Trucks
What is the high pressure reading for charging freon for the air condition?
For charging purposes, you really should be monitoring the low side pressure. Depending on ambient air temperature, the low side should be between 30 and 50 lbs PSI. The high side can be between 135 and 330 lbs PSI.
Sep 19, 2011 | 2006 Chevrolet Trailblazer
How many PSI freon dos this unit take to fill? S3QA-30KA 2.5 TON
unit's are usually charged in pounds not psi...units require a certain pound amount of freon to work properly....... it depends on the outside air temp, the inside air temp.... what type freon ?? need more details on unit and what type freon does it use??
May 10, 2011 | Heating & Cooling
AC blows warm. fan + compressor don't seem to engage.
The system could be low on refrigerant. The A/C pressure switch will not let the compressor run if the system pressure is below 28psi or above 455psi to protect the compressor from damage. At low pressures not enough oil (mixed in with the refrigerant) will circulate, and at high pressures, the compressor seals will likely blow. You can get a set of A/C manifold gauges for R-134a and check the system pressures yourself or get a shop to check it and possibly add some R-134a. If the system pressure checks good, then the A/C pressure switch, the compressor clutch, or some relays will need to be checked.
Feb 05, 2011 | 2003 Honda Odyssey
I Have a 2000 Expedition 5.4, atempted to charge the ac. I was getting a preasure reading but no freon would go into the system. When the compesor cicks on i get a reading of about 30 psi when it goes off...
Add more freon, should have a low side reading at about 30-35psi at about 1500 rpm and stay there, if it drops low pressure switch will cut a/c compr. off.
Jun 10, 2010 | 2000 Ford Expedition
GE GSF25XGR Everything seems to be functioning properly, compressor is running. have supplied freon but its not moving thru the lines.
you mean, it where not able to completely frozen the layers?
if that is the case then your Freon charge might be under charge, it should be atleast 18 to 20 psi the backl pressure of your freon charge when it is running and it can only be measured using gauge manifold, your technician should know about it.
worst case scenario is your compressor might be Loss Compression (mechanical failure) Yes it is running but it cannot make pressure (valve problem)
Nov 08, 2009 | GE GSF25XGR Side by Side Refrigerator
Aircon not working 2001 Jeep Cherokee Sport
There is a pressure valve that keeps the compressor from turning on if it has a low freon charge. Get a self recharge kit that comes with a gauge with colored charge indicator. Hook it up and see where your charge is. It is very inexpensive compared to a pro A/C shop.
Nov 23, 2008 | 2001 Jeep Grand Cherokee
Adding freon to my central air
Well duprees, first you got to have the right instrumentation for charge freon to a a/c system, now, the charge line is the thick line, wich it means the suction line, the colder line, or the most robust line on the compressor.
Then, the system uses freon 22, the right charge, with the system on and the compressor running is 68.5 to 70 psi.
This should give to you about 40 degrees(farenheit) at the evaporator, the panel that gets cold in the system.
This pressure should be at the low side, meaning thicker line in the compressor unit.
Hope this help you......
Good luck.......
Aug 11, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
