Question about LG Washing Machines
Dispenser drawer stuck closed
Wm2277h dispenser drawer stuck closed
  • LG Master
  • 2,271 Answers
A common issue on older lg washers, since fixed with a redesign on newer ones. The immediate solution is to take washers top off and partially take dispenser tray apart to free it. The issue is the fabric dispenser is slightly ajar and catching on a lip of the dispenser top and jamming the tray. Thoroughly cleaning tray and all parts will fix but a more foolproof permanent solution involves filing down the leading edge of the fabric softener tub to a rounded edge so it will never happen again. Not easy, but doable. Two screws in back to take top off by sliding it back about two inches and lifting off. Good luck
Posted on Apr 02, 2015
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Tip
Dishwasher does not dispense cleaning tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
Fabric softner will not dispense
Check if the dispenser hose at the back of the drawer is clogged. Check also if the plastic tab located at the back of the drawer, the one that open and close softener dispenser is broken or stuck.
Apr 18, 2009 | Kenmore Washing Machines
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Cant open soap drawer on washer
I opened up the top of the washer by unscrewing the screw in the back. then I pressed down hard on the white plastic cover of the soap dispenser that you will see on the front left hand side of the machine. I also moved it slightly to the right by pushing on the side of the same unit.
The soap dispenser then opened up fine. I cleaned out the soap dispenser from any crud that developed in it. Now it opens and closes nicely.
Did you know there is a class action lawsuit against LG for mold that develops inside of this model washer? I joined in the lawsuit. There should be no mold accumulating in any washer.
Sep 07, 2008 | LG WM-1485FHD Front Load Washer
Dispenser door stuck
The dispenser assembly has warped and needs to be accessed from the top.  Remove the top panel to gain access to the dispenser.  The top part of the dispenser can be pried off so you could remove the drawer.
Jul 24, 2008 | LG WM2688HWM TROMM SteamWasher
Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
Jun 22, 2008 | LG WM-2277HW Front Load Washer
Sticking dispenser drawer
no other way then force but having got it out you should try to estabish why it is sticking
Apr 01, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
