There are white line in the paper - Office Equipment & Supplies
  • 384 Answers
Assuming that you are talking about a copier, and you are using the automatic document feeder, you need to check the small glass section (about 1.5" wide) for a small dab of White-Out. Just scrape it off with your fingernail, then follow it up with some alcohol, or windex glass cleaner. That should clear up the white line issue!
Good Luck!
Rich Lilja
Posted on Apr 03, 2015
    Master:
  • 395 Answers
Are you using back paper?
Posted on Apr 02, 2015
Line comes up vertically on scanned paper on colored paper only.
have you tried to uninstall the last upgrade? Sometimes they're not working as expected
May 29, 2015 | Office Equipment & Supplies
White streaks and double printing
Usually when a printer can't feed paper evenly anymore, it's worn out. As long as you are using fresh paper and not over or under loading the paper tray, the rollers should feed the paper ok.
Nov 24, 2013 | Office Equipment & Supplies
A black line on the scaned page
If light going around the paper, and if upper white paper don't cover it, this part will be black. Try to cover with some part of white paper around. If you have black line in the middle of scan, you have hardware problem with scanner (or old buggy driver). Try to update scanner driver.
Aug 24, 2011 | Office Equipment & Supplies
White stripe on right as if black toner needs
You probably got a piece of paper or something in the image path or the paper path. If it is a nice clean line it is more likely to be in the image path, if it is smudgy line it something may be scraping the toner off the paper before it gets to the fuser. Check the paper path.
Dec 26, 2009 | Dell 3010cn Laser Printer
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
White lines Xerox docucolor 12
do an emergency stop on the machine as the paper is just coming into the main path, and you will catch the inage on the IBT. with a bit of luck on the drum as well. Is it not in 1 colour the white lines? Also are they thick or pencil like lines and from lead edge to trail edge?
Jan 01, 2009 | Xerox DocuColor 12 Color Copier
LONG WHITE VERTICAL LINES
It sounds like the drum may need to be replaced. The streaks may be caused by sections of the drum no longer being able to hold a charge and therefore, toner will not properly stick to the paper in those sections and you'll be left with long white streaks on the paper. This is a usual symptom of a bad drum.
Jan 13, 2008 | Sharp AL-1000 Laser Printer
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
29 people viewed this question
jasbo
jasbo
