Question about Canon imageCLASS MF5550 All-In-One Laser Printer
Canon MF 5750 All in One- Paper Jam
My copier has a paper jam that is in the front of the unit. The paper will not budge. I call "support" and they told me that because of the location of the paper jam, I have to take it in for a service call. Since it is 2 yrs old I will have to pay for it. Is there a solution that I can do? I cannot carry this to a shop and would prefer a free solution.
5 Suggested Answers
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Posted on Jun 18, 2009
  • 1447 Answers
SOURCE: printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Posted on Aug 04, 2009
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
  • 383 Answers
SOURCE: Cannon All in printer MF
look for the paper jam at the back of your printer.
Posted on Jan 22, 2011
Testimonial: "Canon mf 5750 Rec paper jam"
0 characters
1 Points
Canom MF 4200 shows paper jam, I removed the paper, but still shows jam
That's probably because the printer didn't recognize that the problem was solved (you removed the paper). Try powering off the printer and back on. That should solve the issue.
Mar 13, 2011 | Canon Printers & Copiers
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Paper jam message...but no paper is jamming system
is a small finger plastic, stucked on the paper path, release-it and problem solved. (Is very fragile, so use a small tool to release)
Dec 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer canon mf 5750 thankyou verymuch
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon Copier MF 6530 stopped printing after a paper jam, everthing else works fine no error code just won't print. I have remove the cartridge shook it and still nothing. Do you have any suggestions?...
I would reset the Photo conductor unit. It will have a Green drum in it. I would make sure it is set in the machine all the way, and that the drum door opens completly. BLANK copies are and indication the paper has NOT touched the drum to recieve an image.
Apr 04, 2009 | Canon imageRUNNER 5570 Copier
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Re: Paper Jam
I'am sorry to say that you have to replace the fusing unit on that machine, when it jams inthe fuser like that the fusing unit is going bad. the fusing units range from: $200.00 to $295.00 plus service call. You may think about replacing it, sorry for the bad news. I've worked on about 5 of those machines with the same problem and it always comes down to replacing the fusing unit, even if you get the paper out it will jam again.
Nov 16, 2007 | Canon imageCLASS D761 Copier
Canon imageCLASS MF5550 All-In-One Laser Printer Logo
115 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
