SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
SOURCE: Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working)
electrical outlet. Then check the appropriate circuit breaker and reset
it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the
drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a
few moments, after the door locks, the washer should begin to spin.
(For your safety, the washer will not tumble or spin unless the door is
closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900
for toll-free assistance and service scheduling if necessary.
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
