Question about HP Photosmart C8180 All-in-One InkJet Printer
How to take apart blk inkjet set up to clean clogged ink in jet?
  • Vicki k Gibson
    Vicki k Gibson Apr 08, 2015
    This is a great video, one I could not find! I thought I found one, but this is way better. Thanks for your input and help! I will start taking mine apart now...I will let you know if I can do so, as the C8180 tends to have a few different components like the lightscribe driver.
    New Friend:
  • 34 Answers
This video take down is for a c5180 but from the scanner down the insides should be basically the same.
Posted on Apr 03, 2015
  • Vicki k Gibson
    Vicki k Gibson Apr 10, 2015
    Hi Derek...I totally cleaned the lines, head and everything right up to the printer pump. The black tubes were very clogged, and now it is all unclogged unless the pump has problems. However, once I got everything together I no longer seem to have any power going to the touch screen and buttons. The touch screen was working fine before I took things apart. All connections also seem fine. Is there any way to trouble shoot that now? I unplugged my C8180, put it into the WALL< as it seemed to not turn on unless it got power from the USB port...why I have no idea. Anyway, I now have power, to only the CD and the power button. Touch screen was working fine until things were restarted. Blank screen. Nothing, no buttons are lit or working. HELP! Any ideas would be nice as I love this silly machine. When working was the best I owned for quality! I updated all drivers for this machine too, so that should not be the problem...I hope!Thanks- Vicki
Printer prints every 2nd or 3rd line of a Word Document in pale gray ghostly way
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Nov 29, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Color ink cartridge show a full ink supply, but it won't print color.
It's possible that the ink-jets that spray the colour ink onto the paper have become clogged. Run the printer software, and select a "print-head-cleaning-cycle", to try to unclog those jets.
Oct 17, 2010 | Dell Inkjet 720 Printer
New ink cartridges, but it won't print, clogged inkjets, how do I clean them.
There should be a utility that runs a program that will clean the ink jets. check your manual. there also may be a button on the printer.
check the printer settings in the control panel, there should be a link to the printer software that allows you to run the cleaning utility.
May 18, 2010 | Epson Stylus 880 InkJet Color Printer
How can you clean the printer but clicking on
Hi
If yourPSC 1210v printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your HP 56 57 still has ink? Empty they are about 30g Each 1g over that is 1ml of unused ink.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a littleMagic Inkjet Flush to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 02, 2009 | HP PSC 1210v All-In-One InkJet Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Got a new computer and the printer may not be set up correctly its not working
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog?
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to usethe Magic Inkjet Flush kit to soak the print head and you should beprinting again like new.
Good Luck!
Tinteiros (Ebay)
Oct 31, 2009 | HP Photosmart C5180 All-In-One InkJet...
After cleaning the nozzles, the quality of print is still very poor. What should we do?
HTML clipboard HTML clipboardHi
However, if like most... and your printer has just been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Good Luck!
Tinteiros (Ebay)
Oct 30, 2009 | Canon Office Equipment & Supplies
Clogged ink jets prevent printing any thing. how
You can try to use the software the came with your printer on your computer to clean the heads. If that doesn't work then you will need to buy new ink cartridges.
Mar 23, 2009 | Epson Stylus CX6600 All-In-One InkJet...
No BLK and Yellow
More info please mikehuang,
When you replaced ink, did you reset ink settings. Do this if not. Also i recommend a thorough cleaning to make sure ink is running out well and heads are not blocked. cheers lilacgerry xxx
Feb 10, 2008 | Office Equipment & Supplies
Red and Yellow not Printing at all.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Oct 16, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C8180 All-in-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
