Question about Plustek OpticFilm 7600i Ai Scanner
Grey/blue vertical stripe has appeared on the left side when scanning
The stripe is becoming progressively deeper in colour after every scan. What can I do?
Pionner avh-x2550bt wiering diagram
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
I just want to no what colour does what job on my sony cdx-l480x player just ripped it out my old car and cant find the wireing diagram
Yellow: battery constant 12v Red: Ignition 12v Black: GND ground White and White with Black stripe: Left front speaker. White is positive (+) Grey and Grey with Black stripe: Right front speaker. Grey is positive. (+) Green and Green with Black stripe: Left rear speaker. Green is positive. (+) Purple and Purple with Black stripe: Right rear speaker. Purple is positive. (+) Blue: Antena remote turn on. Blue with Wite stripe: Amplifier remote turn on. I think thats all of them. Make sure to connect your positives and negative correctly or you will have phasing problems. dreamsystems
Feb 08, 2011 | Sony CDX-L480X CD Player
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Plustek OpticFilm 7600i Ai Scanner Logo
Top Plustek Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
