Question about Vehicle Parts & Accessories
This car had a 305cid . I bought this car with a 350cid . how do I tell the year of motor
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Read the casting number on the block, then look on the internet to decipher it. 350 blocks from the late 60's to 1979 had dipstick in th block on left side, 80-86 on the right hand side, 87 up had one piece rear main seal, 93 start showing up with roller cams, 96 Vortec. All the blocks have unique casting numbers. Most also have a factory stamped serial number on the front of the block somewhere, often under the left cyl. head
Posted on Apr 02, 2015
83 c10 truck 305cid 2wd blower motor does not blow
You will need to replace the relay under the hood in the fuse panel
Feb 14, 2014 | 1A Auto Parts 1983 Chevy C10 Truck 12...
Chevy caprice problems
With any luck...
This years tax time repair could just be that leaky exhaust (Rusty muffler or plugged CATALYTIC CONVERTER)..
Annual repair is pretty good... (better than most)
but the TWO you don't want to put off
Brakes & Exhaust (ignoring could be fatal).
Just know your prices before going to the
local friendly EXHAUST SHOP.
Your car shows 4 engine choices in 1986
(5.7 showing)
1986 CHEVROLET CAPRICE 5 7L 350cid V8 Catalytic Converter RockAuto
rockauto
1986 CHEVROLET CAPRICE 5 7L 350cid V8 Muffler RockAuto
Carnac the Magnificent
Mar 29, 2017 | Cars & Trucks
Under hard acceleration my 69 gto has blow by
350CID engine? pontiac engines have all of there horsepower below 5000RPM, if you accelerate past that you will cause damage unless the engine was built aftermarket to handle it, you may have bad rings or worn rings.
Sep 23, 2012 | Pontiac GTO Cars & Trucks
Small Block Chevy Rear casting number 3970010 and front casting numbers 1416454889 K01-09-CMF Can anyone tell me what size motor is this and what year it is?
I can't tell you the year but the rear casting number 3970010 is usually a 350cid. Year range 1969- 1985. I if you will run the VIN # found on a pad at the front of the pass. side of the block just in front of the cylinder head it will tell you the info your looking for.
May 28, 2012 | Engines & Components for Chevrolet Chevy
WHAT YEAR IS THIS MOTOR? ENGINE # IS T4F732649 THEN THE SCECOND SET IS VO737TJC, I KNOW IE IS A 350CID 4BOLT MAIN. I WOULD LIKE TO KNOW WHAT YEAR THIS IS MY NAME IS THANK YOU
T4F732649 Is cylinder head number after 1975 some where around 77-79 look for the casting date code is stamped right under it ; VO737TJC is this the number on the deck pad it is underneth the intake manifold unless you have the intake off you will never see the engine`s stamp code
Aug 29, 2011 | Computers & Internet
What year and application is Chevrolet small block cylinder head casting number 376450?
Hello, the heads you have are from 1975&1976 262cid and 305cid engine's,intake valves are 1.72 and exhaust valves are 1.5001.hope this helps you.Thank You for using FixYa........... Ray
Jun 22, 2010 | 1983 Chevrolet Camaro
I just want to know what motors will bolt up to the s10 2.2 transmission
the 2.2 is a 4 cylinder and all other stock motor's for an s-10 are v6's if the motor your thinking of is a 4.3L vortec then good choise, it and a 350cid v8 use the same bell housing but u will have to upgrade to a tranny from the larger engin's to make it work, and to hadle tha added pewer reliably
Jun 04, 2010 | 1998 Chevrolet S-10 Pickup
Hearing knocking sound when engine heats up in my infinitiQ45 2002 model
I don't think the news will be good. It sounds like a bearing is compromised on a connecting rod. I suppose it could be a main bearing as well so here is how to tell which. It the engine siezes completely, it is the main bearing. If you see a connecting rod come out you'll know it was that. A bad main bearing produces a very deep thunking noise and usually vibration. With main bearing failures, the metal bearing inserts will actually melt and weld themselves to the crankshaft then evrything comes to a quick halt.
There is one other option that has a pretty good chance of being the problem and that is that your timing chain has jumped a gear which is throwing off everything else. I would check this out first because it is repairable since I believe that engine is a non-interference engine meaning no valve damage. Put a timing light on it and you will be able to see if it is off a notch.
If all else fails and the rest of the car is still good, buy a crate motor. I bought a Target (not the dept store) engine, 5.0L (305cid) and it was much better than the original. Jasper makes them and there are a bunch more. Even junkyards have the 5.0L around all the time but the 350's are harder to find and go quickly.
Jun 25, 2009 | 2004 Infiniti Q45
Have 95 geo. don't know what year the engine is.
try looking for an identification or model number on the engine block and Google it
Apr 07, 2009 | 1995 Geo Tracker
Any way to tell what year it was made?
and I never knew what year it was as it was newly rebuilt. Is there any way I can tell?SB5X005779 is the serial number on the bottom of the motor.,,
Nov 10, 2008 | 2000 Ducati 996 Bi~ - Monoposto - SPS
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
