Question about Ovens
HI i have put in a new grill, where fan is constantly on, does this mean I have connected to live and neutral crossed ?many thanks martene
  • Ovens Master
  • 3,463 Answers
Normally, when you have the grill on, it is usual for the cooli9ng fan to come on, so I do not think you have a problem.
Posted on Apr 02, 2015
Live wire connection has 3 connectors for 3 phase. Do I put in all there bridges when connecting to single phase
Your question is not mate. What do you exactly want to do? If I understand that you have a single phase apparatus you wanted to connect it from a three phase box. If that is the case, then you have three options:
1. If the wires are new colour coded ones then you have to take your neutral wire from the blue wire and the live from any of the other three.
2- for old colour codes , take the neutral from the black wire and the live from any of the other three.
3- finally. Connect the neutral from the black or blue and the live from any of the other three red ones if the wires are in a conduit or trunking. I hope this answers your questions. Good luck
Jan 13, 2015 | Ovens
All oven grill and fan elements dead
The oven will not warm if the clock is not set as the main oven is directly linked to it. You may want to check your wiring to the element you have changed as all elements use the same neutral path, meaning if you missed a wire off (especially if you pulled it out through the oven cavity) or have put them on the wrong tab it won't work. It could also be a duff element (the new one).Let me know if you need any further help.
Dec 07, 2011 | Neff Ovens
Ive taken element out to replace with new but have forgotten the way the wires went back.there are three spade connections the earth is obvious but not the live and neutral
Hello Ian,
You can put the live and neutral on either of the outer terminals terminal. It really doesn't matter. It's the same principle as not needing to screw in a bayonet light bulb a certain way round. As long as the circuit is complete, it will work correctly.
To put it in the simplest terms, attach the earth wire to the shorter centre terminal with the live and neutral wires on the two outer terminals and job's a good 'un.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 18, 2011 | Belling XOU252 Electric Single Oven
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I...
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Nov 09, 2010 | New World 70TC Electric Single Oven
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
Only one light comes on, nothing works
Your problem is related to incoming power or range internal wiring.
Verify 220 volts to the range. Pay attention to the wire connections being tight especially the neutral wire.
Oct 01, 2009 | Electrolux EOB5665G Ultrafan Electric...
Error " service 34 -6-
check polarity means you have the live and neutral to the oven swapped over, you need to change the live and neutral. service 34-6 means there is a communication problem with both the fan motors but this will probably be cured when you swap the live and neutral
Mar 01, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Electrical supply
HI Zuso,
Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
Nov 23, 2007 | Ovens
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
