Question about EliteGroup GeForce 6100SM-M Motherboard
Bios hanging when cpu check begins
Bios can detect only cpu name (no information more). After that just hanging. No keyboard and other peripherical stuff detected. CMOS cleared - no results better. Also RAM changed. What to do??
  • 1 more comment
  • Ville Farm
    Ville Farm Apr 11, 2015
    I consulted with friend, who said: try to load flash. If this fallout then "academicaly" computer is dead, Of course if i would want to re-write bios-stone handly. So i try this way tomorrow and let know here too!
  • SXTechHead
    SXTechHead Apr 12, 2015
    There is no need to reflash the BIOS, unless there was already a problem? What cpu are you using??
  • Ville Farm
    Ville Farm Apr 18, 2015
    AMD 3,4GHhz AM2 socket.
  • 79 Answers
Sounda like the cpu is at fault, or you have not inastalled it or the heatsink correctly.
Remove cpu and heatsink, re-assemble ensuring good connection to socket AND good connection to heatsink with high quality thermal paste, available from any pc store.
Failing that you need another cpu to check that that indeed is the issue.
Posted on Apr 05, 2015
  • SXTechHead
    You don't need to reflash the BIOS, unless there was a problem in the first place? What cpu aree you using??
  • SXTechHead
    SXTechHead Apr 18, 2015
    Great; it's an AMD cpu - I think we know that. WHAT MODEL?? Also NO 3.4GHz cpu's are listed as compatible:http://www.ecs.com.tw/ECSWebSite/Product...
  • 70 Answers
Dear ur processor is going heat.may there is an air space in ur heat sink and processor.u can try any thermal paste for filling any air gap.or it may some bad capacitors.sorry for bad english
    Top Expert:
  • EliteGroup Master
  • 12,962 Answers
U can try dropping in another cpu, and removing all peripherals except the memory and see if it recognizes it. If problem persists the anomaly lies within the cmos of the mo bo or the mo bo itself.
If the cpu is now recognized add the peripherals one by one till the problem reappears. The last item you added is causing the hassle.
Posted on Apr 03, 2015
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
The ECS C51GM-M Motherboard problem is that the fans turn but no video, no post, no bios.
This could be due to many things. One is a bad power supply. Any peripheral that is bad could cause it. Your memory could be bad. I would unhook every peripheral/hardware but the video cable, memory, CPU and keyboard/mouse. If you get video then one of the other things are bad. For instance, I have found that a bad CD will prevent a system from booting.
If you have no luck, then the problem lies in the motherboard, memory, or CPU. To eliminate the memory possibility, take one stick of memory out and try it.
Sep 11, 2010 | ECS C51GM-M Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
MSI RS482M4 Mobo not recognizes USB port on XP SP2-3 boot.
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Computers & Internet
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Computer won't boot or won't even enter setup
Try disconnecting all peripherals then boot up, except for those you need, i.e. video card, keyboard... If that doesnt work you may need a BIOS update... Refer to the picture below to find your BIOS code, the four numbers represent the date which you must use to find out if you need an update...
Apr 03, 2009 | Biostar U8668D (802700113338) Motherboard
Emachine
F10 should get you into BIOS.
Jul 27, 2008 | HP Pavilion dv9000z Notebook
Motherboard_prob
just check is the processor fan is running or not then try with new ram,power supply,
Jul 21, 2008 | ASUS Computers & Internet
My pc intel p4 2.4gzh hanging
hmmmm....i think that the bios system might be confuse...Check that your cpu is install properly..
May 18, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
EliteGroup GeForce 6100SM-M Motherboard Logo
193 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
