Question about Volkswagen passat * note technical
How to mount intercooler, condenser, radiator and fans for passat 1.9tdi 2007
  • Elphus Maseko
    Elphus Maseko Apr 06, 2015
    How to mount intercooler and the radiators to the craddle before fastening the bumper and grill
3 Suggested Answers
  • 2920 Answers
SOURCE: vw passat intercooler
it will become a bigger problem if you dont get it fixed. small problems always tend to get bigger
Posted on Nov 12, 2008
  • 12 Answers
SOURCE: My vw passat tdi 05 radiator fan dose not come
check fuses..came across a bora with much same problem..it turned out to be a coolent tempreture switch the heater gauge wasn't working and on diagnostics it was reading -41degrees celcius the fan was not running because it thought it was freezing outside also blew the fuse of the fan also
Posted on Jun 19, 2009
How do you remove the radiator on a 2007 chrysler sebring limited 3.5
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove radiator upper crossmember support. WARNING: DO NOT REMOVE THE CYLINDER BLOCK PLUG OR THE RADIATOR DRAINCOCK WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
  3. Drain the cooling system.
  4. Remove the radiator fans.
  5. Disconnect coolant reserve/recovery hose.
  6. Remove vapor purge solenoid from mounting bracket.
  7. Disconnect upper and lower hoses from the radiator.
  8. Remove the A/C condenser side brackets to radiator attaching screws. Separate the condenser from the radiator by lifting upward to disengage from lower mounts. Allow the condenser to rest in front of radiator.
  9. Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal.
  10. INSTALLATION
    1. Be sure the air seal is in position before radiator is installed. Slide radiator down into position. Seat the radiator with the rubber isolators into the mounting holes provided, with a 10 lbs. force.
    2. Position air conditioning condenser onto the radiator lower mounts and install upper screws. Tighten fasteners to 5 Nm (45 in. lbs.).
    3. Install the radiator upper and lower hoses.
    4. Connect the coolant reserve/recovery hose.
    5. Connect the vapor purge solenoid to the mounting bracket.
    6. Install the radiator fans.
    7. Install the radiator upper crossmember support.
    8. Fill the cooling system.
    9. Connect negative cable to battery.
Nov 10, 2016 | 2007 Chrysler Sebring
Secondary fan keeps running on 2007 passat
Check radiator fluid. If full consider have the radiator cleaned and/or cooling system flushed out.
Jul 01, 2014 | 2007 Volkswagen Passat Sedan
How do I remove the intercooler from my 2007 Santa Fe 2.2CRDT?
maybe the radiator? the thing that sits in front of the engine with the fan aimed at it? in that case, youll probably have to take off the fan housing, drain it via the drain plug at the bottom left or bottom right of it (dont do that if you have had the engine running recently itll burn) let it drain. take off all of the hoses connected to it, then it will be secured somehow around the edges, undo those points and it should come out. id suggest taking another approach at getting the 4th screw out however. smaller/different angled tools often do the trick
Oct 20, 2012 | 2007 Hyundai Santa Fe Limited
Replace raditor 2001 chrysler 300 M
1. Remove or disconnect the following:
  • Disconnect negative battery cable.
  • Drain cooling system.
  • Upper radiator hose .
  • Upper radiator closure panels.
  • Radiator fan assembly .
  • Radiator fan electrical connector.
2. Raise the vehicle
3. Remove or disconnect the following:
  • Lower splash shield.
  • Lower radiator hose.
  • Lower condenser mount bolts
4. Lower vehicle.
5.Remove or disconnect the following:
  • Upper radiator mounting brackets and bolts.
  • Upper condenser mounting bolts.
6. Separate condenser assembly from radiator.
7. Tilt radiator toward engine and remove radiator from vehicle.
Clean radiator fins are necessary for good heat transfer. The radiator and air conditioning fins should be cleaned when an accumulation of debris has occurred. With the engine cold, apply cold water and compressed air to the back (engine side) of the radiator to flush the radiator and/or A/C condenser of debris. The installation of the new radiator is the opposite of the removal. Please upvote if this was helpful. :)
May 04, 2011 | Chrysler 300M Cars & Trucks
How do I replace a intercooler for my 2005 VW Passat TDI?
TO REMOVE INTERCOOLER. YOU RAISE THE VECHICLE AND SUPPORT IT SECURELY ON JACKSTANDS.REMOVE THE ENGINE COMPARTMENT UNDERCOVER.DETACH THE AIR DEFLECTOR FROM THE INTERCOOLER.LOOSEN THE HOSE CLAMP AND DISCONNECT THE UPPER AIR DUCT FROM THE INTERCOOLER.LOOSEN THE HOSE CLAMP AND DISCONNECT THE LOWER AIR DUCT FROM THE INTERCOOLER.REMOVE THE MOUNTING BOLTS AND REMOVE THE INTERCOOLER.INSTALL NEW INTERCOOLER IN VISA VERSA.
Feb 04, 2011 | 2005 Volkswagen Passat
About how long will it take to replace the radiator?
About 2.5 hours
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  • Tools Required
  • J 38185 Hose Clamp Pliers
Removal Procedure
110563917
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
  1. Remove the battery.
  2. Remove the air cleaner assembly.
  4. Remove the right and the left engine mount struts. Refer to the following procedures:
    • Engine Mount Strut Replacement - Right
    • Engine Mount Strut Replacement - Left
  1. Use J 38185 to remove the inlet hose clamp from the radiator.
  2. Remove the inlet hose from the radiator.
  3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
110563918
  1. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
110563919
  1. Remove the cooling fan shroud bolts.
  2. Remove the coolant reservoir hose from the radiator overflow neck.
110563920
  1. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  2. Disconnect the engine cooling fan motors electrical connector.
  3. Remove the cooling fan motors electrical harness from the fan shroud clips.
  4. Remove the cooling fan shroud.
  5. Remove the bolt from the condenser tube support bracket to the radiator.
  6. Use J 38185to remove the outlet hose clamp from the radiator.
  7. Remove the outlet hose from the radiator.
  8. Disconnect the transaxle oil cooler pipes from the radiator.
  9. Tilt the top of the radiator rearward.
110564721
  1. Remove the condenser hold down bracket (1) from the radiator.
  2. Remove the air deflectors from the top of the radiator.
  3. Lift the condenser from the mounting tabs on the radiator (2). Position the condenser aside.
  4. Remove the radiator.
Jan 02, 2011 | 2004 Chevrolet Impala
Range rover p38 radiator removal info
First, remove the grille, then the top panel. Remove the viscous coupling and fan. Remove the top radiator mounts, Remove the coolant hoses and oil pipes, remove 4 bolts holding the A/C and intercooler/or PAS radiators (depending if yours is diesel or petrol.) then lift up and out the radiator. Fitting is reversal of removal.
Hope this helps
Nov 20, 2009 | 2000 Land Rover Range Rover
How do i replace the radiaor? on this 2005 Hyundai do i remove the intake cover, then the cooling fan, the the motor mount? what?
Below are instructions and a diagram for removing the radiator from your Santa Fe. There's nothing involving the motor mounts. Best of luck and please post back with any questions or just to rate the solution. Greg
  1. Drain the cooling system. Remove the radiator cap to speed draining.
  4. Remove the fan shroud clip from the condenser tubes.
  5. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
  6. Remove the air deflectors from the top of the radiator.
  7. Remove the cooling fan shroud bolts.
  8. Remove the coolant reservoir hose from the radiator overflow neck.
  9. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
  10. Disconnect the engine cooling fan motors electrical connectors.
  11. Remove the cooling fan motors electrical harness from the fan shroud clips.
  12. Remove the cooling fan shroud.
  13. Remove the outlet hose from the radiator.
  14. Disconnect the transaxle oil cooler pipes from the radiator.
  15. Tilt the top of the radiator rearward.
  16. Remove the condenser hold down bracket from the radiator.
  17. Lift the condenser from the mounting tabs on the radiator and position the condenser aside.
  18. Remove the radiator.
Aug 11, 2009 | 2005 Hyundai Santa Fe
How to replace a radiator in a chrysler concorde 1998 3.2
drain radiator.. remove upper and lower radiator hoses ,,remove transmission lines..remove bolts from cover on top of radiator.. lift out radiator.
Dec 06, 2008 | 1998 Chrysler Concorde
Volkswagen passat * note technical Logo
37 people viewed this question
Top Volkswagen Home Experts
john h
Tom Chichester
Are you a Volkswagen Home Expert? Answer questions, earn points and help others
