Question about Refrigerators
ZISS360DHSS water dispenser
Water dispenser keeps running
  • Refrigerators Master
  • 473 Answers
Could be 2 possible problem areas for your problem. 1st there is a small switch inside the dispenser area that when you press for water the switch closes and sends power to the water inlet valve which then opens and lets water come out. That switch could be stuck and needs replaced. 2nd, the actual water inlet valve could be stuck open and if it is then it needs replaced. The inlet valve is the plastic valve the house water line connects up to on the refrigerator. It will usually have 4 wires plugged on to it. 2 of them are for water dispense and 2 are for water to the ice maker. Will also be 2 plastic tubes attached to it along with the house water line. Not hard to replace but make sure you don't get anything mixed up.
Posted on Apr 02, 2015
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
Keurig B150 - continuous water dispensing
Their appears to be a scale build up inside the valve that dispenses the water when demanded. This is an electrical solenoid much like in fridge water dispensers but smaller. The scale is not letting the valve close completely after dispense. On a regular brewer running vinegar thru the machine a couple of cycles will usually dislodge the obstruction in the valve. If you can manually add water to the brewer, you should add the vinegar instead to clean the valve. Otherwise you may have to disassemble locate the valve and soak in descaler, or vinegar.
Jan 11, 2015 | Keurig Coffee Makers & Espresso Machines
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running how do es the door
the problem is noit in the door its on the back of the unit where the solinoid valves are located. Whats happening is the valve is leaking by.or there is too much water pressure. I would replace the vaalve first though.
Mar 29, 2009 | Refrigerators
Ice and water in the door
sounds like the water valve is sticking replace the water vavle
Nov 29, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
