Question about Polaroid FLM-3201 Television
When i turn it on it shows ...NO SIGNAL VGA INPUT ... cant get it to do anything else
  • 4 Answers
If all the other inputs are working then the trx rcv IC's have gone bad in the module. you can buy a replacement module they are easy to replace contact me and i can get you one.
Posted on Apr 02, 2015
When i turn on the TV all that comes up is...NO SIGNAL VGA INNPUT, cant get it to do anything else
Disconnect all inputs. Unplug set from AC for 1minute plug back in and turn on set. Press menu and select input Antenna, cable,HDMI video etc. Connect source to that input.
Apr 02, 2015 | Polaroid Televison & Video
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
Ive connected my vga to vga cable from my desktop pc to the rgb pc input on my lcd tv but it shows no picture. it shows windows loading but wont show my password entry or desktop page
Because your laptop needs it's display setting changing so your second monitor is active.
While on your desktop, right click once and a box will appear, choose "properties" at the bottom.
There you will see another box, choose the "settings" tab at the top right and this will show your display options.
Right click on the number two box and "attach" it.
You may also have to change the size of the display to fit your tv.
Hope this helps
Dec 01, 2013 | LG Televison & Video
Im havin problems settin my laptop to my telly my telly is 47inch baird ive attatched the vga lead but nt sure what i do
You may have two settings to change; make sure that your laptop has its external VGA turned on. You may have to access the CMOS setup or choose an external monitor from the Control Panel - Display settings.
On your TV, you will have to change the input selection which is probably set for 'Cable' now. You didn't mention the model number of your set so can't check which verbiage is available through your menu. Once you have found the input selection section of the TV menu, if VGA is not specifically mentioned, just have material set up on your laptop (movie or similar) and step through the possibilities - slowly - so your set has a chance to see if signal is available from the selected input.
If it is still telling you 'no signal,' your laptop may still not be outputting anything to the TV.
Aug 27, 2011 | Televison & Video
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Polaroid FLM-3201 Television Logo
49 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
