Question about Chrysler 2007 Sebring Touring
Cam shaft sensor, how much to replace?
Crank correlation sensor code
SOURCE: Ware is the crank sensor located on a chrysler
should be at the right rear of engine block just ahead of the transmission
Posted on Dec 09, 2009
  • 75 Answers
SOURCE: Ive replaced the cam shaft sensor but need to see
The crank shaft sensor is located on the front of the engine under the timing cover. In order to replace it you will need to remove the timing belt.
Posted on Jan 23, 2010
SOURCE: my O5 pt crusier stop in the middle of the road
The crank shaft sensor will be fitted over the front crankshaft pulley or where it can read the electronic signals generated from the flywheel....The way it works is to receive a magnetically generated signal which is transmitted to the management computer system....It basically indicates when the piston is at the ignition point of the engines cycle...As we're dealing with a four stroke engine, remember that the crankshaft makes four revolutions to two of the camshaft....The cam will give its own signal via its own sensor....Both are used to control the spark and firing of the plugs in the correct sequence and at the correct time....If the scan tool said the crank sensor I'd think that's the fault and stick to that....
Regards Johngee10
Posted on Oct 16, 2010
  • 5 Answers
SOURCE: where are the cam and crank shaft sensors located?
the crank sensor is located in the bellhousing of the transmission and very easy to get to and its most likely the cause of the problem
Posted on Oct 20, 2011
emissionwiz
  • 76164 Answers
SOURCE: 2004 chrysler sebring 2.4l dohc.
Have you ever replaced the timing belt?? If not the problem is likely to be a loose worn out timing belt. A floppy belt will play havoc with the sensor signals and trigger a check engine light and a camshaft sensor code.
Posted on Jun 22, 2012
Eng code p0016
P0016 fault is poor crank/cam correlation. In other words the signals the ECU is receiving from the crank and/or cam sensors isn't making any sense and this could be caused by bad cam timing, wiring, connectors or the ECU itself or by faulty sensors but as you have changed these, probably not.
Sep 13, 2015 | Cars & Trucks
What does this code mean
Does the truck run ok? If so may just be bad sensor .it reads the correlation between cam and crank shafts so timing is correct so the camshaft control the valves and crankshaft controlling the pistons don't hit each other
Jul 02, 2014 | 2000 Chevrolet Blazer
2002 VOLVO S80 T6 CODE P0017
the word correlation means relationship between two or more items . In this case it means that when the crank shaft sensor is triggered then the camshaft sensor has to be in agreement that the position of the piston and valves is in the right position to allow spark and fuel.. there are air gaps between each sensor and the rotor that triggers them and if this is not correct or there is dirt in the air gap ( the sensors may be a bit advanced or retarded in the fitment holes) then this relationship of positions is being interfered with and so you get the fault code. If after rechecking the fitment of the sensors and using a scanner to put the engine light off ,you still have a problem ,I would suggest that you find an accredited shop the does a lot of work on your make of car to assist with the fault.
Apr 23, 2014 | 2002 Volvo S80
P 0016 code
Code 16 is for a problem where the correlation between the crank sensor and the cam sensor for bank one is off. So yes it could be the cam sensor or the timing belt. If compression is normal on all 6 cylinders I would expect to find a bad sensor.
Jan 22, 2014 | Chrysler 300M Cars & Trucks
Camshaft position sensor correlation bank 1 code
timing belt is off by a tooth or two. you probably didn\'t have to replace the coolant sensor; that code sets whenever the sensor is disconnected and the ignition is turned on; and it needs to be reset by disconnecting the battery or with a code reader. anyway, the crank/ cam sensors are out of sync. if you\'ve got the twin cam engine, they are a royal pain to get the belt to lay properly on the two cams.
Apr 15, 2013 | 2007 Chrysler PT Cruiser Touring Hatchback
I have a 98 chevy z71 5.7 350 vortec, i have a p1345 code that stays on i clear it and as i restart the truck it comes back on, the truck runs great and has a small delay when starrted.. what can/do i need...
1345 is cam and crank sensor correlation its mainly the cam sensor going out, also the delay start that also trigger a camsensor code they call it excessive crank time check the fuel pressure that is capable of setting a cam code (1345) If fuel pressure is good (55-60 psi) expect to replace the camsensor you might as well do the crank sensor heres a nightmare on this code it can set if the distributor is off one tooth and yes these distributor have high failure rate
Jun 08, 2011 | 1998 Chevrolet K1500
I have 2008 Dodge Caliber and the engine light came on with codes P0017 Crank Shaft Position Cam Shaft Position Correlation - Bank 1 Sensor B can you tell me what this means as i cannot afford to...
Sounds like your crank sensor or cam sensor is malfunctioning. Their positions are not correlating which means they are not in perfect alignment according to the computer. I don't think the parts are very expensive and probably not that hard to replace. I replaced both on my 99 Ford Explorer, and I don't recall it that difficult. Anyway, hope this helps.
Mar 17, 2011 | Dodge Caliber Cars & Trucks
What is code P1345?
I had the p1345 on my 2002 Silverado this week. The code means Crankshaft/camshaft position correlation. In other words the cam is not where it is supposed to be in reference to the crank. It could be the Cam position sensor, the crank position sensor , the gear on the distributor or the timing chain. The quickest and cheapest check is the distributor gear which is what mine was. It's quite common. The gear is about $60 and can be replaced in less than an hour with the right experience. The engine won't usually run if it's the crank sensor and the cam sensor is a little more.
May 27, 2010 | 2002 GMC Sierra
2003 caravan will not start!!!
Hi..
On your problem with the Caravan.
If you Have replaced the Crank and Cam sensors. And the Code Cam/Crank Correlation sensor.
Is found.
Normally this code is present When the Timing belt or Timing Chain, Is out of time 1 or more dents
On the timing due to Skip of the timing belt or Chain.
But don't forget check the connector at the sensors. For any damaged or corrosion on the pins.
Ok.. I hope this help to try diagnostic your car.
Thank you for use fixya.
Nov 03, 2008 | 2003 Dodge Caravan
Chrysler 2007 Sebring Touring Logo
22 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
