Question about Exercise & Fitness
My treadmill when I step on stop. The motor is going but no the bell
  • 473 Answers
Your belt is either worn or out of adjustment and too loose. Some treadmills actually have 2 belts depending on the drive system. Some have a small belt that goes from the actual motor to a pulley that is attached to walking belt drive system. If the big walking belt is tight you may have that system and the small belt needs tightened. Other systems have the motor connected directly to the big walking belt and in this system my guess would be the big walking belt is loose. Most have adjustment screws at the back end of the treadmill frame along side the belt to make it tighter. Adjust both sides the same so it tracks straight.
Posted on Apr 02, 2015
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
I keep getting an init error message on my life fitness treadmill. How do I fix this? It comes on every few minutes and the treadmill stops. Please help! Thanks.
reset the treadmills, with the small button underside to the power button with small pencil click the switch, AND TRY AGAIN.
Otherwise RUN the software calibration for easy diagnostic go under the HOOD cover motor, and follow the steps
God bless you
Sep 19, 2013 | Exercise & Fitness
Belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
sincerely. God bless you
Apr 27, 2012 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Tread mill
1) yOU must use the calibration software , use your owner manual or go under the hood for to see the explanation and step for diagnosotic and fix it
2) Test the lmain motor controlller board for input 115vca +5vdc output to the circuit for inclintATION MOTOR.
3) Test the motor from incliantion motor tight the connector 4) Adjust the pot in the motor 5) THE gear slip can be adjust and repair.
Nos see my block diagiram that I did for better undertanding and easy diagnostic,. See how the main motor board has the 90% functions of the any treadmills. sincerely. Merry Christmas.
erensto cuadra
managua, nicaragua.
Dec 23, 2011 | Nordic Track C2255 Console (treadmill)
The treadmill runs fine until i step on it then it stalls and stops running
There is a motor which spins the treadmill belt.When you start the treadmill, the motor starts running and belt spins smoothly.But when you step on the treadmill, the motor cannot take the load and it stops working.In your case, the motor and motor control board is got weak and this is causing the problem. ---------- Or the other possibility is the treadmill belt, the belt on which you step.That belt should be smooth, there is grease in the inner side of belt to keep it lube and run fluently.If that oily grease gets dried up then belt gets bit stiff or jammed up, when a load is on belt.So get this both possibilities checked.First try lubing the belt internally and then try check the motor and motor control board.To locate motor control board its simple.On the side of motor you will see a electric plug in connector, the other end of that connector gets connected to motor control board.Remove that connector , clean it and reconnect after 5 minutes, then check.In some cases this resets the internal control system and everything, works normally.But its not always possible then removing and reconnecting connector helps.In other cases the motor or control board needs to be replaced.If the motor gets weak, then internal coils in motor gets burned up.----------- This will help.Thanks.Helpmech.
Mar 26, 2011 | Proform Exercise & Fitness
Sqeeks when you step on the belt; mainly on the right side. Also bell hangs up, sometimes almost coming to a stop, especially at low apeeds.
hi,
your treadmill's belt is loose. You have to tight the belt from the both side.
all the treadmills follow the same procedure for tightening the waking belt. Watch the following video for the same.
ok
Mar 05, 2011 | Proform CrossTrainer Treadmill
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to...
hi,
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Jan 01, 2011 | Proform iLog 750 Treadmill
Treadmill stops when I step on it?
your running belt might b on 2 tight or u dont have enough power going 2 the motor make shure u have a designated power line 2 your machine
Dec 20, 2009 | Proform 730 Folding Treadmill Model...
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
