How DO i Fix DVD Writer Works As CD ROM Only. Not Detecting any DVD.
DVD Writer DRU 170C Works As CD ROM Only. Not Detecting any DVD. . Tried With Power DVD install. No result. Open Case Detached Primary IDE Channel, then uninstall the Secondary IDE Channel (DVD Drive Fix to it) from Device Manager. Still Not resolved.
    Genius:
  • 1,552 Answers
There are 2 assemblies inside it.
One works to read/write CD media.
One works to read/write DVD media.
So, your device is "half-broken".
Replace it.
Posted on Jun 05, 2015
sandrew
  • 2961 Answers
SOURCE: Samsung DVD writer
Sounds like you have done all you possibly can, it may well be that the drive has finally given up and a replacement is neccasary. You can try to repair the autorun .inf file, but i think a replacement. http://www.microsoft.com/downloads/details.aspx?FamilyID=C680A7B6-E8FA-45C4-A171-1B389CFACDAD&displaylang=en Sorry!
Posted on Apr 16, 2007
  • 833 Answers
SOURCE: How do I install a DVD drive as well as my CD-RW?
mst...First, get your manual out. the drive must be set to be a secondary device unless it is not. You say you have only one IDE...did you remove the CDR? If you have a second IDE or other board connector, then this drive is primary on that. Now, did you install the drivers for the unit? You can use your CDR to do that or get them from the website of the manufacturer. Are there any bent pins on either the motherboard or the back of your drive? Somewhere in there is an answer.
If you have only one drive connector set, you can get a board which will allow you to setup additional drives. Ask your dealer.
Posted on Dec 17, 2007
  • 1019 Answers
SOURCE: CD/DVD Writer drive not detected
is it showing As Drive D:- Or E:- In My Computer ?
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 192 Answers
SOURCE: i have a sony dru
Update your Chipset drivers, and download the updated drivers and Firmware from Sony:
http://sony.storagesupport.com/product/125#documents
Hope these solve your problem
Regards,
Tim
Posted on Dec 10, 2008
bronk50
  • 27725 Answers
SOURCE: my pc doesnt detect my
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Posted on Oct 31, 2010
Hi, i am using LG dvd rom HL-DT-ST_DVD-RAM_GSA-H55N on Windows XP platform. my dvd writer is detecting cd's but not detecting dvd's.i had flashed the dvd rom by LG firmware but that does not...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard
hope this helps you
Sep 10, 2011 | LG GSA-H55N DVD-RAM Burner
My sony CD Rom problem is that the computer is detecting the CD Drive but the CD Rom is not detecting the CDs
then you should clean you cd rom using a cleaner and stil if it doesn't respond you have to change the ROM
Mar 17, 2011 | Sony Computers & Internet
My lg dvd writer is not detecting dvd but it is detecting cd...
the laser (lens) of the Rom is very weak, that's why it cannot read DVD discs. DVD discs are usually larger that CD's and it takes an active lens to play DVD disc.
So if its still under warranty, you can return it, if not, get a lens cleaner and use it to clean the lens of your ROM.
Good luck.
Jul 03, 2010 | LG GSA-H55N DVD-RAM Burner
I have a sony dru 820a dvd writer,it is not detecting the cd/dvd when inserted but it makes some wierd sound and does not read the inserted media. it was also interferring with booting of PC but once the...
ur registry is corrupt...
try cleaning the registy
visit my website www.sureshayyar.110mb.com
go to dowload page in there...get Tuneup Utility...install, clean the registry....
also try runing chkdsk...if u know how to do it...
all the best
Dec 25, 2009 | Sony DRU-820A DVD RW Dual Layer Burner
Can't write dvds
i have same problem. i tried to fix it myself but didnt work its the problem of dvd-writer no problem with software, i know becoz i took my friend's dvd-writer and its woking absolute fine, so better take it to some hardware repair shop.
Oct 02, 2009 | Computers & Internet
SONY DVD RW DRU-830A "d:\ is not accessible. Incorrect Function."
generally d cd,dvd writer or cd,dvd player of SONY creates dis problem it is unable to read local disks due to high sensitivity of dere lenses...
i hv seen in many cd,dvd writers havin dis type of problems...
it can not made....
but i would prefer u to use LG cd,dvd writer which is capable of readin all local or orignal disks..
Jun 16, 2008 | Sony (DRU720A) DVD±RW Dual Layer...
Bootable CDs are not working with my new DVD writer
Try to update your BIOS first, then call me in the morning.
Nov 26, 2007 | Acer TravelMate 2303LCi Notebook
DRU-810A not booting bootable cds
check your boot order in your bios and set your cd drive to first boot
Nov 18, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
My SONY DRU-810A DVD Writer doesn't work with TDK DVD+RW Disc
some dvd brands dont work with all dvd writers, so your option is to try another make, if that works ok then it's not a writer fault it is just that the media make is not compatable. if you start to see problems with all makes of disc then the writer laser is faulty and a replacement drive neccasary.
May 11, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
