Question about Krups XP4030 Espresso Machine
Pump won't stop pumping
As soon as I plug the machine, the pump is pumping water constantly and won't stop as it should after some seconds. What do you thing is the problem? Thank you!
  • Krups Master
  • 1,280 Answers
It sounds like the electronic PCB has failed and is supplying current to the pump all the time. It's not the sort of repair that a homeowner would be wanting to tackle. They are not made with ease of repair in mind. I would advise getting a quote from an authorised Krups service agent or just binning it.
Posted on Apr 02, 2015
Circulation pump runs constantly as soon as you plug in the machine until it is unplugged
MAY HAVE A PROBLEM WITH THE ELECTRIC SIGNAL FROM THE TIMER OR CONTROL BOARD TO THE WATER PUMP
Jul 20, 2014 | Whirlpool WTW6400SW Cabrio Washer
Drain pump runs constantly
Your Motor controller board is faulty and needs repair.
Apr 04, 2013 | Fisher and Paykel Washing Machines
Water pump out for one second and stop
Semi-Plugged exit port. Clean as per manual
Aug 07, 2012 | Keurig B70 Coffee Maker
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Pump runs constantly while machine is on
there is a hose inside the fill tank that should connect to a water port if the hose came off this could be your problem.....
Sep 27, 2009 | Breville Die Cast 800ESXL Espresso Machine
I have a rule 1800 computerized pool cover pump. As soon as I plug it in, it runs a few seconds then shuts right off, WON"T keep running. (this is outside of the water, dry) any help?
That's a good thing. That pump uses resistance on the impeller to alert it to the presence of water. It will periodically start and run for a few seconds. If there is any water present, it will keep running, otherwise it will shut off until the next time it tries. Put it in water, and see if it works there.
Dec 12, 2008 | Rule H53sp 24mgra Swimming Pool Cover Pump...
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Krups XP4030 Espresso Machine Logo
161 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
