Question about Ohio Steel Lawn Roller - Steel, 48in.W x 24in.Dia., Model 48T
How do I fix 48 Steel lawn roller that leaks water by the axles
Used 2 seasons and roller now leaks water by the axles. Will now only hold 1/2 drum of water. How can this be fixed?
  • Moxie
    Moxie Apr 24, 2016
    The axel or shaft is solid and goes thru the roller on both ends. It appears to me that one of the welds broke at the point where it goes thru the roller, which would cause it to leak. I would take off roller handle, remove a hub if you have one , just grind tack welds off that hub that covers where axel goes thru hub, don't over grind as rollers are usually made of thin gauge material. Once you expose axel where it comes thru roller you'll be able to see most likely a broken weld. Center axel if weld is completely broken to the drum. Use low heat ( amps ) when welding or you will make a bigger hole. I've fixed many of these rollers over the yrs and when they make these at the manufacturing plant, welders sometimes are in a hurry and results in a poor incomplete weld. If your not that good of a welder, take it to a weld shop.
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
Sep 19, 2016 | True TSSU-48-12 - 48 Sandwich Salad Prep...
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Replacing new tines or a complete new drum
flexrake.com/1f-lawn-rake-head-only-flex-steel.html
Apr 29, 2014 | Flexrake Lawn Rake With 21 Flexpoly Lexan...
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Lg dryer replace drum rollers
never lubricate a drum roller ,it will attract lint and hold it like a magnet possibly making your problem worse. graphite lube possibly - as used in door locks.but this will be only a temporary fix. replacement is the only way to go.
Feb 27, 2012 | LG DLE2512W Electric Dryer
Upper rack roller axles are brittle and 1 has
Our upper wheel failed. It is part of the huge assembly called the "Rack Adjust" on our model # PLD4460REC Frigidaire Dishwasher and cost $88 to $120. Hey.. thanks to the guy above I was able to fix my machine without spending to much!! for a huge part when all I needed was the upper wheel. the part # for the upper wheels is = PS976006 and is for another model dishwasher (Sears located it for me first.. without trying to make me buy the huge assembly) but might work... I will order and give them a try. The model # referenced about seems to be incorrect... We used model # PLD2855RFC1... as google helped us fill in the missing part# letters. I asked frigidaire... why they encouraged customers to borrow this small part from the store display.. why not just sell it!! .;)
Aug 02, 2010 | Frigidaire PLD4460REC Stainless Steel...
Water dispensing but also leaking from the back
Pull the fridge out and remove the back panel . Have someone press the water dispensor and watch for the leak . Usually , the plastic line at the water valve breaks off , and removing the broken piece and reinserting the line , fixes it . You may have to remove the 1 screw holding the water valve on , to gain access to remove the broken piece of line . The water valve itself , could also have a hole in it , spraying , due to long period of water pressure . Just replace the water valve , if this is the problem .
Sep 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
1993 Ford F-150 drum brake problem
It appears the rear axle shaft seal is leaking. You will need to pull the axle and replace the seal. Then check the rear end for adequate gear oil. The iron filings I am not to sure about. It sounds as if something came loose from the brakes or brake hardware and got chewed up in the drum. You will need to replace the brake shoes and maybe the brake hardware kit. Always change the shoes or pads on both sides when working on brakes, rear or front. If the inside of the drum is not perfectly smooth it will need to be turned or replaced. If this were brake fluid leaking from the wheel cylinder the master cylinder would be low on fluid and your brake pedal would go down much further than normal.
Jul 18, 2009 | 1998 Ford F150 Regular Cab
Leak in formed pond
It worked for one season on mine. As the crack got older it became longer and wider. Mine was due to not sinking the pond all the way into the ground which caused stress from the weight of the water causing it to crack more. The second season I used a water epoxy putty I bought at home depot in the glue dept. It is greenish blue and turns white after mixing and can be used underwater if necessary. I filled the gap and then placed the repair liner like you are showing over the top and sealed the edges with a black waterproof silicone. This also worked for a season. Now the crack is even larger and wider and nothing I am doing this year is holding! I can't seem to find one the same size and shape or I would replace it. My next attempt is going to be a plastic welding kit, but I haven't tried it yet. Good luck.
Jun 05, 2009 | Epdm Lp1, /Pvc Liner & Preformed Pond...
Ohio Steel Lawn Roller - Steel, 48in.W x 24in.Dia., Model 48T Logo
746 people viewed this question
Top Ohio Steel Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ohio Steel Garden Expert? Answer questions, earn points and help others
