Question about Exercise & Fitness
This treadmill require a magnet I bought it used did not have it
    Scholar:
  • 93 Answers
You can try using a strong refrigerator magnet. It's not coded or anything.
Otherwise, you can go to http://www.treadmilldoctor.com/treadmill-parts-model-select and pick your brand and model and order the part. Probably under "accessories" somewhere.
The treadmill should have a label with the model and part number.
Posted on Apr 02, 2015
2 Suggested Answers
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
Lost magnet treadmill
Hello. In the mean time you can use a fridge magnet to get you back on the machine. You might need a strong magnet, so if the first one doesn't work keep trying.
try googling the brand of machine you have to purchase parts or try eBay under treadmill safety keys.
GymWorld.net.au
Jan 10, 2014 | Exercise & Fitness
Elliptical resistance
please follow this steps and fix it. Merry Christmas
·2
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 17, 2013 | Exercise & Fitness
God bless you
May 22, 2013 | Xterra Fitness Xterra FS220e Elliptical...
No tension on pedals for nordic track trl 625 recumbent bike
God bless you
Apr 01, 2013 | Exercise & Fitness
Resistance too high
Feb 18, 2013 | Life Fitness X3 Elliptical with TRACK...
I bought a used Life Fitness 95T from a fitness center, the display displayed "please replace safety switch to continue workout". The Magnetic switch is in place but the unit does bot recognize...
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_11_41_39_am.gifThen tight the flexible cords from keypanel vs display board( clean the keypane with spray from contact cleaner. then tight the connector from display board vs main motor controller. Remember the main motor controller has aprox 90% of functions of any treadmills. See the block diagram that I did for people like you, And now you will get powerful strong resultant what is wrong. sincerely. Good luck.
finally 2 options: 1) display faulty 2) Main motor controller of course after you did the first step.
Oct 08, 2011 | Life Fitness 95Ti Treadmill 95 Ti
One day, after 47 minutes my treadmill powered down and would not remain on upon restarting the machine. After letting it sit for about an hour the treadmill would come back on and seemed to function...
Watch this video:
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=E-q-uS4t6so
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Sep 07, 2011 | Nordic Track NordicTrack Treadmill, A2550
Norda track t5zi when i press go the motor start for about 1 second and then the screen goes dark and then restarts itself. incline works fine. Bought brand new but I have only used this thing a dozen...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
May 16, 2011 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
