Question about 2000 Mercedes ML55 AMG Window Regulator g63431035i 163 Type; ML320, ML430 and ML55 Omaha, Nebraska
When I start the engine it cannot keep running, it tries to start only to shut off
    Scholar:
  • 102 Answers
Ok. I guess the best way to start is, did this just start or has it been a problem for a while. Another idea I'm having is have you had any ignition problems? Guess what I'm asking is does it start run for a few seconds then stop or does it sputter a little before it quits? If it just stops I'm going to point to ignition, like your coded key may be a problem they have to tall took each other. If it his pop boom bang. Not really. Then vacuum leak or throttle body air, fuel filter stuff. Good luck. Jim
Posted on May 05, 2015
    Master:
  • Mercedes-Benz Master
  • 342 Answers
It sounds air/fuel related. I would start checking there...Air filter, fuel filter, Air idle control ect..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_4c166ba81493f541
Posted on Apr 07, 2015
JD GT 275 cranks OK but no start. It starts when connecting shutoff solenoid to the battery. Can I cut grass running it that way?
you can take it out and spray some lubricant on it and work it to free it up but most people just cut the tip off that way it wont shut fuel off. they are expensive thats why most will cut the tip off.
Mar 23, 2018 | Garden
Starts fine runs fine. After turned off, will not start. Wait or try again and it starts. What's wrong?
Car will sometimes not start after warm. - CarGurus
www.cargurus.com > Questions > Pontiac > Grand Prix
CarGurusJan 2, 2013 - When i start my car, for the first time during the day- I have no problem.... When I go somewhere and shut it off, sometimes it won't resatrt. ... I have to keep my foot on the gas and rev it up to keep it running- then it's fine. .... When your carstarts fine cold, then fails to restart while warm, it is usually a coolant ...
Blazer has to be jumped, then i shut it off and won't start.
www.cargurus.com > Questions > Chevrolet > Blazer
CarGurusDec 21, 2013 - I jumped it and it ran fine, but as soon as I turned it off I couldn't start it again. No clicking just like the battery is drained. ... Then run the car for ten minutes and shut it off and if does not start, replace the battery. ... Blazer starts fine first time but after shutting off,has hard time starting-takes up to 10 key turns or ...
Engine Performance Problems Due to Crankshaft Position ...
repairpal.com > Problems > Mercedes-Benz > ML320
"Crank no Start" Due to Failed Crankshaft Position Sensor on Mercedes-Benz ML320... It usually ocurs after I've turned the car off and try to restart after about 15 minutes. I typically allow it to ... fine. Stalling and starting problems intermittent at first, but now more frequent. ... Car runs fine then without out warning it won't start.
Jan 05, 2016 | Cars & Trucks
My 1999 the engine keeps just shut off while driving down the road the engine keeps turning but wont crank I put some engine starter in the carb.and it tried to start.could it be the fuel pump
if it was the fuel pump engine should start with starter spray at least for a second or two, so, it sounds like your fuel pump is bad.
turn ignition to run and try hearing the pump run.
Dec 17, 2014 | Cars & Trucks
1994 chevy cvalier 3.1 engine...lately it's been shutting off when i come to stop. the oil pressure fluctuates and then shuts off. it always starts back up. any suggestions?
if this unit has an over drive tork converter the tork converter or the TC valve (solenoid) might be faulty, have you tried keeping your foot on the gas a bit to keep it running ? and what happens ? also some engines have a low oil pressure warning and engine cut out , did you check your oil ???
Jun 10, 2012 | 1994 Chevrolet Cavalier
VAN SOUNDS LIKE ITS TRYING TO START AFTER I SHUT IT OFF
this is what we call "dieseling"
it is the engine running WITHOUT spark plugs
This happens when you have leaking injectors and carbon build up in the engine (pistons/valves)
try shutting off the engine while in park
keep your foot on the brake because you might find the engine has enough power to actually move the van
keep us posted
Apr 12, 2010 | 1998 Dodge Caravan
My 1991 toyota pick ,will start but shut off ,
I would check out the Mass Air Flow Sensor. Located on top of the air filter box. If the sensor is bad and computer doesn't see air going into the engine, it will automatically keep the engine from running. Try pulling the engine trouble code to confirm is problem.
Oct 11, 2009 | 1991 Toyota Pickup
Fan keeps running for 15 minutes after engine is shut on my Hond
Either relay will have to be replaced or the sensor. They usually run mabey 5 minutes top afterwards.
Aug 28, 2009 | 2000 Renault 181
Fan keeps running after engine is turned off
why does the cooling fan start working as soon as i start the car and doesn't shut off until i turn off the car?
Oct 05, 2008 | Mitsubishi Lancer Cars & Trucks
2000 Mercedes ML55 AMG Window Regulator g63431035i 163 Type; ML320, ML430 and ML55 Omaha, Nebraska Logo
97 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
