Question about Xerox Phaser 6128MFP AllInOne Laser Printer
My Xerox Phaser 6128MFP printer flashes red light after every print out....
My Xerox Phaser 6128MFP printer flashes a red light after every print out with a message saying Load paper in Tray 1, paper type: letter size: 8.5 X 11.0 inches . The paper type and size on the printer and PC are already the same. The printer kind of gets stuck with the red light on, until the tray is removed and re-inserted. Then, the same thing recurs. Please help urgently.
  • 34 Answers
First, when you put the paper in the tray make sure the paper holders on the side and back of the tray are positioned against the paper stack but not so much as to be snug.
Next, inside the compartment where the paper try is inserted look for a small plastic piece that hangs below the ceiling of the compartment. It should be near the front of the compartment hanging down and should swing freely backward.
Also, in the printer's paper tray settings make sure that tray is set to that size of paper you are using.
My Xerox Phaser 6128MFP printer flashes red light  - 25623526-hmg2kbc0xprjju4gp0h4roxd-1-0.jpg
Posted on Apr 02, 2015
  • Sameer Khan
    Sameer Khan Apr 05, 2015
    Thanks a ton for the info. Doing that and changing the paper settings in the laptop solved my problem.
    Master:
  • Xerox Master
  • 551 Answers
Dear Khan
pl.check paper sensor leaver Registration for working properly. I.e. return to its position after passing the paper.
thanks.
Testimonial: "Thanks. Will try it."
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
What is the error 017-988 for phaser 6128mfp
It's a scan from PC error. Most common problem is that the destination folder for scan does not exist. Does it give that error on just a plain text document as well? It could be the document type and settings. Hardware wise could also be a main board issue.
Oct 20, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
How do i no if the imaging unit needs replacing or reset an how much does it cost if it needs replacing
try this links:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=160,E=0000000005460300657,K=9193,Sxi=12,Case=obj(5359)
http://r.search.yahoo.com/_ylt=A0LEVvsi_JtVbFYAvWBjmolQ;_ylu=X3oDMTEzY2MxZzlyBHNlYwNzcgRwb3MDMgRjb2xvA2JmMQR2dGlkA0ZGR0UwMl8x/RV=2/RE=1436314786/RO=10/RU=http%3a%2f%2fdownload.support.xerox.com%2fpub%2fdocs%2f6128MFP%2fuserdocs%2fany-os%2fen%2fimaging_unit_IS.pdf/RK=0/RS=3MJAHme.0NoW97ngNUbYHHYUWY4-
4results for xerox phaser 6128 imaging unit
Sep 22, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
What is the life of a Xerox 6505 toner cartridge
The life of a toner cartridge is governed by how much printing it does.
As an example: the average full toner cartridge was expect to yeald approximately 10.000, A3 prints of approxamatly 5% coverage.
That equates to your average business letter :=
Dear Sir, blah, blah, blah ... Yours sincerely.
If you want to print construction plans and black and white drawings expect to get less prints than you expected.
On average they don't do too badly, but if you want to print advertising flyers expect less if there in full colour with bleed.
If you print 4 colour black then don't expect not to use the C,M & Y that also gets used up at a similar rate.
Good luck.
Jun 09, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Printing without the white side lines
I think the problem is not with your printer but with page set up. Try going into settings for your printer and reduce the margins.
Jan 03, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Phaser 6505 imaging unit life reset
HELP.. replace transfer unit... I replaced it.. still a
replace transfer unit message.. help!!
Nov 27, 2013 | Xerox Phaser 6128MFP AllInOne Laser...
Xerox phaser error code 117-313
ke significa quando ti compare errore comunicazione controller errore 117-313?
Dec 16, 2012 | Xerox Phaser 6128MFP AllInOne Laser...
Phaser 6128 mfp error sensor ctd
Open up the side panel that houses the toner cartridges. One by one pull out the toner cartridges, with a clean dry cloth clean off the injection port(?) on the cartridge and the injection port on the printer(this will be just inside the where the cartridge locks in. Sometimes these ports get clogged with toner and need a good cleaning, causing a CTD sensor error. Our 6128mfp does this error all the time and we have not had to purchase the new parts to fix the error.
Aug 07, 2012 | Xerox Phaser 6128MFP AllInOne Laser...
How to define gmail smtp to work with xerox phaser 6128MFP?
Instead, contact your local Internet Service Provider, and ask them for the name of their SMTP-server, e.g., 'smtp.isp.com', and use that name.
Aug 16, 2010 | Xerox Phaser 6128MFP AllInOne Laser...
Phaser 8500dn error code 13,266,44
You have either an intermittent Electronics module or a intermittent print head. Lowest cost new from Xerox is $750.
Phaser printers are expensive.
May 05, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 6128MFP AllInOne Laser Printer Logo
133 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
