Copies come out severely wrinkled. What is causing this?
    New Friend:
  • 34 Answers
If the "wrinkles" are wavy or bubbly in nature then it's likely the fuser. If the "wrinkles" are making bends in the paper then it's likely there is some debris in the paper path or it is catching upon exit.
Copies come out severely wrinkled. What is causing - 25623515-hmg2kbc0xprjju4gp0h4roxd-1-0.jpg
Posted on Apr 02, 2015
    Master:
  • 553 Answers
Dear Joseph
The problem with fuser assembly.
Thanks.
Aficio MP 1800l2. Why are copies sometimes wrinkled?
Wrinkling can be due to misalignment of the feed path or use of paper stock that is too thin.
Nov 13, 2015 | Ricoh Office Equipment & Supplies
Riso Rz 990U after printing few copies there are wrinkles on master. How to fix that?
the master should be scanned once with the number of copies being entered as the rest of the copies then are printed from the memory
Aug 22, 2015 | Office Equipment & Supplies
Why is my photo copier wrinkling the paper sometimes?
Check the lower pressure roller at the heater unit for damage.Also see to it that the copies are alligned before it enters the heater unit ..
Aug 01, 2014 | Toshiba 6LH58317000-OEM Estudio 355...
Why is my paper coming out wrinkle Dell B1160W
Could be a number of factors.. first humidity affects paper, if there is moisture in your paper...caused by air conditioners constantly running .
check the paper by placing the back of your hand to the paper that is in the paper tray and or the package for a very cool feeling, this will definitely cause the paper to wrinkle when coming out of the fuser unit.
Also it could be charging of the paper during the transfer stage..which can be checked by starting a copy and trying to catch it before the paper enters the fuser rollers ..too late if it comes into contact with the upper and lower pressure rollers of the fuser unit.
Also the fuser unit definitely needs to be checked as a major source of wrinkling of copies..sometime the fuser roller will start loosing some of it's coating which you can easily check by viewing the condition of the upper roller.
Anyway it's either moisture in the paper, charging of the paper, or the fuser unit is the probable suspect.. check them all.
Jul 09, 2014 | HP LaserJet 2840 Printer
I need help repairing my copier. The pages are wrinkled when they come out. I was making multiple copies when it paper jammed twice in a row. i removed the paper (no pieces left) and now half of my paper...
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 04, 2011 | Office Equipment & Supplies
Copies are coming out wrinkled - always in the same spot.
You can try to stop the process mid-print. That way if the paper is un-wrinkled before it hits the fuser, then it must be the fuser causing your problem.
The PN for the fuser is FG6-3720-000 and sells new for about $175
Whit
Item, inc.
Sep 16, 2010 | Canon PC-940 Black and White Copier
Copier wrinkles copies
It cuold be that paper has too much moisture or you nned to replace press roller bushings alonh with cleaner and fixing film
Apr 30, 2010 | Canon PC-940 Black and White Copier
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
141 people viewed this question
k24674
jasbo
jasbo
