Question about Pool & Spa
My pool wont backwash but filters fine - Pool & Spa
  • 1,631 Answers
Sounds like maybe your waste line is blocked. Any valves on it that did not get opened?
That is what I would look for, or maybe the line is naturally blocked or clogged?
Posted on Apr 16, 2015
Testimonial: "I've changed all the hoses and pipe on inside of filter had to dump all the sand out put it back together and it still want backwash when in filter mode it sucks a big dent in the filter please help"
  • Mike Tellegen May 02, 2015
    Can you upload a picture or two or three? I would like to see what you have, the way it's plumbed, etc. I would be glad to continue to assist. I know it's starting to get to swim season! Let's start there.
Old triton pool sand filter....2 orange valves.. What is the position for filtering and backwashing?
orange valves are for the returns the backwash is the skinny rod with the black handle check flow of pool I think up is backwash down is filter
Sep 09, 2015 | Pool & Spa
Hi, I have a thermoplastic sand filter t450 model. Every time I leave it in filter mode, water from the pool seems to drain out rather than filter water from pool. When I leave it in backwash mode,...
The "spider"gasket in the backwash valve needs to be replaced. It is not hard to do. If you undo the 6 bolts on top of the valve lid the "key assembly" will lift straight out. Inside the valve body you will see the gasket.
Aug 06, 2013 | Pool & Spa
My pool filter wont stop backwashing it is in filter cycle it wont stop even when i shut the pump off it still drains
Underneath your backwash valve handle is a gasket that looks like a wagon wheel. This has worn out and needs to be replaced. Your pool store may have one or you may have to get one from the manufacturer.
May 29, 2013 | Blue Wave Sandman Above Ground Sand Filter...
Pool filter backwashes on all settings
Time for either a new Multivalve Gasket or possibly Cam. You will need to Disassemble.
Jul 09, 2012 | Hayward SAND FILTER, PRO SERIES
I have a Hayward S310T filter. It's been running 24/7 for over a month. The water does not appear to be clear, even after floccing. How do I tell if the water is being filtered or if the filter is...
Backwash the filter. If the water coming out of the backwash line is not dirty you need a sand change. If the water is dirty you need to continue let the water filter and back washing once a week. Also make sure the six way is on filter and not recirculate
Www.theswimtimeonline.com
May 26, 2011 | Hayward SAND FILTER, PRO SERIES
My pool is a 24x52 intex and the pump wont work
Try backwashing the filter until the pressure is between 10 and 20 psi. (backwash for a couple min then run it on filter for a min and so on until the filter pressure is normal). If this doesn't work, the hose may be cracked/punctured, if so you will need a new hose.
Jul 16, 2010 | Aqua Vac Tiger Shark
No green comes out in backwash
Alge will quit often go through filter so first you need to kill the alge by super chlornateing the pool. You can take a water sampel to your pool store and give them the size of your pool, they can test your water, for nothing in most cases and recomend what you will need for this. Then you can start cleaning the mess up as the dead alge will turn to dirt. This dirt will be very fine and may go through your filter also so a cup full of D.E. in your skimmer after backwashing will usually coat the top of your sand and catch much finer dust and dirt. Do this as you clean the pool and backwash 1-2 times daily till clean. Follow all directions given to you at store to kill the alge first, this is very importiant.
Aug 09, 2009 | Hayward Sand Filter System & Tank 21" 1...
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward pool motor shuts off in backwash mode.
Check the pump suction filter? To backwash it, is to
open the backwash tank cleanout valve, to clear the dirt out. If this does not work, check the pipelines going to the backwash tank for clogged lines.
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Pool heater wont fire up
check pressure switch for continuity with pump on
Jun 07, 2009 | Pentair MINIMAX NT TSI IGNITER
Pool & Spa Logo
150 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
