Question about Yamaha Audio Players & Recorders
I have a Yamaha KXW302U audio tape player. And when I play a tape on the A deck, after one second, it stops.
If I have a tape in the B deck it reverts to the B deck. If I don't have a tape in it, it just stops playing after one second.
  • Yamaha Master
  • 1,258 Answers
The auto stop function is activating due to lack of reel rotation on the TU reel and so you may need a reel drive Idler tire or a new belt.
Posted on Apr 02, 2015
Stop Paying .. ????
if the take up side gets stuck it could feed excess tape and stop the mechanism. Look to see if both reels are turning when you push play. Remove cassette door for a better view if possible.
Make sure your tapes have NO slack in them. Fast forward and rewind one cassette all the way, then try again looking to see if both sides are turning. If not, you may have a belt that is old, stretched and slipping or it's split apart or just fallen off
Sep 11, 2015 | Yamaha Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
Playing a tape on Deck B stops after a few seconds. Tried over and it stops again after a few seconds of play.
Either tape is tight, run it ff the rev all the way back, or transport is failing , motor , belt , pulley etc,
check tape or try another one in deck b, how is deck a
Sep 21, 2009 | Onkyo TARW255 Single Dual Cassette Deck
How can I get VHS tapes to play?
try to run a vhs cleaner thru it and it should help alot
Jul 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
DECK B PROBLEM ON RARELY USED MACHINE
if the heads are getting jammed in the up position it may be a failing capstan belt in the transport not disengaging the transport properly. replace the capstan belt. If one has failed both will probably be bad.
Oct 06, 2007 | Yamaha KX-W321 Single Cassette Deck
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Sep 24, 2006 | Aiwa XR-C3RW Shelf System
208 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
