Question about Coleman River Gorge 20;F Sleeping Bag
We are unable to re-zip the red zipper because of a 2nd zipper behind the red zipper. Can you help?
Can you replace a zipper on my tommy hilfiger backpack. The zipper splits apart after being zipped up.
No, we can't replace a zipper, we are here to answer questions. We're not a repair service.
You may be able to cut off the zipper and sew a new one on. It depends upon what material the backpack is made of.
Nov 16, 2016 | Tommy Hilfiger Watches
A zipper replacement for a tommy hilfiger back pack. zipper breaks open, after it is zipped close.
You can do a google search for "tailors" in your area, call and ask them if they would replace/repair a zipper on your back pack.
This FixnZip item may also work, without any sewing needed.
Zipper Repair Without Tools or Sewing FixnZip
I am trying to insert a zip. The needle is not moving far enough to the left or right so that it doesn't hit the zipper foot. Please help
try using a 1/2 foot as this will allow the needle to get close to the edge or zip
commonly used for making a rope edge
available from any sewing machine shop
Aug 01, 2015 | Sewing Machines
The zipper on my Asos dress split and it is stuck in the middle of the zip with both ends open. Now I can't zip it down
Hold the zipper that both sides are parallel then go upwards then downwards . Once u go upwards look it could be a little thread stuck in it .
Coz it's a plastic zipper it happens just get it replaced .
Aug 30, 2014 | Sewing Machines
My zipper on my jacket wont zip up.
Make sure it is properly hooked at the bottom. Get a cake of soap and rub it on all the zipper teeth. Carefully and slowly try to ease the zipper up. Also,make sure there is no material caught in it.
Oct 13, 2013 | Eureka Tundraline Tent
Ziploc slider bags with smart zip seal does not open! This is the 2nd box I have to throw bag after bag away because the slider does not open the bags! This is unacceptable!
Take it back to the store where you bought them. I think maybe you're not holding the bag the right way in order for the zipper to lock and unlock.
Aug 07, 2013 | Ziploc Slider Freezer Bag, Gallon Size
Zipper won't zip up its almost shut closed
If all the teeth of the length of the zipper are snapped together, it is closed and the pull piece is all the way at the ends of the two matching sections. It appears jammed at that point, right? If so you may need to use a little muscle to pull the end links one way and the zipper tab the other. A pair of plyers sure could help.
Jan 23, 2013 | Crafts & Hobbies
Zipper will not work on the rear window. Trying to determine if I need to replace the rear window. OEM top, believe it is made by Besttop, sunrider version. Have had problems with this window for last...
Have you confirmed the alignment of the lead/end part of the open-side of the zip, with the closed/slider side.?
Getting the first bit aligned properly it vital.
Whether it's a metal or nylon zip, a bit of lubricating spray will help get the two sides going.
You may need to get a hairdryer (or heat gun if you're very, very careful) to warm-up the cover to allow it to stretch into position, if it's gone stiff in the garage whilst you've not been using it.?
Don't force it, ease it.
Forcing the zipper is likely to tear the stitching &/or the vinyl.
Best of luck.
Mar 06, 2018 | 2009 Jeep Wrangler
How do I fix a zipper that won't zip?
I take it that your slider won't connect the two sides of the zipper but just slides along.
This is a common problem and is caused by the slider having opened up a bit.
Get a pair of pliers and gently squeeze the slider front to back so it'stighter on the zipper, this should do the trick.
(Check the zipper for a cracks first, if it's cracked this will be a very temporary fix.) There is acompany that makes a replacement slider that can be fitted to an existing zipper called ZlideOn www.zlideon.se
I carry a pair of these in my backpack, one latrge size for the tent and one that fits my jacket/sleeping bag/inner tent.
Ingenious product!
Aug 09, 2010 | Eureka Tundraline Tent
Zipper problems
if the bag cant be replaced! then i would recomend replacing the zipper with velcro (might have to sew it somehow) but thats what i would do if it were mine-----thanks
Mar 04, 2009 | Craftsman Garden
Coleman River Gorge 20;F Sleeping Bag Logo
428 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
weirdtop
oldhess
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
