Question about Exercise & Fitness
How do I get treadmill out of safe mode - Exercise & Fitness
  • 3,960 Answers
Not knowing what type of treadmill you are talking about, please Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results. You can then find how to get the unit out of safe mode.
Posted on Apr 02, 2015
Safe key/lock out error
Mine has the same error, have you found a fix?
Mar 04, 2014 | Schwinn 840 Treadmill
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Power on screen shows safe
Reset the treadmills. and proceed again. God bless you
adjust the REED switch, clean it, test for open or faulty, tight the connector very well. see the diagram.
Jun 16, 2013 | Exercise & Fitness
Reset Console from Safe Mode?
i RECOMMEND that you wait until the arrival for your parts. In electronic many times, the PROM or ROM, etc not coming for to do the same thing as the old chip .tHEY HAVE discrepance. By that reason it better wait. Otherwise you must have some conflicts. However you can restore to the factory if you can do it,meanwhile the part arrive you
God bless you
Jan 31, 2013 | Nordic Track Nordictrack C 2150 Treadmill...
Nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Jun 14, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
249 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
