Question about HP Officejet 5740 Wireless e-All-in-One Printer
How do I copy from document feeder? - HP Officejet 5740 Wireless e-All-in-One Printer
    New Friend:
  • 34 Answers
Insert document in the Auto Document Feeder until you feel the paper stop. Place the document so you can see what is to be copied. Then press the copy button and press start. By default that should make one copy of your document.
Posted on Apr 02, 2015
    Master:
  • HP Master
  • 553 Answers
Dear Flaim
pl. do load documents on the adf tray.face upward and the press copy or start. it will do
thanks.
HP5610 - HORIZONTAL STREAKS ON COPY & SCAN
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
Aug 28, 2017 | HP Office Equipment & Supplies
Tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 | Xerox C2424 Copier
3055 glass
There is no need to change the mode. When the document is loaded on the document feeder, the screen displays "DOCUMENT LOADED" and shall copy or scan this document. To copy or scan from glass, DO NOT LOAD ANY DOCUMENT IN THE FEEDER. The printer will automatically copy / scan from glass.
May 10, 2013 | HP LaserJet 3055 All-In-One Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Jan 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 5740 Wireless e-All-in-One Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
