Question about LG Heating & Cooling
Error code ch n ch2 lg air con
Unit turns off comprosser upon power on
    Sergeant:
  • 71 Answers
I would check your manual to see if it has anything on the code you're talking about. Hopefully it will have troubleshoot instructions. If not give human resources a call. You could even try looking online for a manual as well.
Cole Air Conditioning Appliance Co Athens Tyler Corsicana Texas
Posted on Jun 22, 2015
    Novelist:
    Champion:
  • 373 Answers
Indoor inlet pipe sensor. Cause of error, Open/short, Solder poorly, internal circuit error.
Check point & Normal condition, Normal resistor 5 ohm at 25 C unplugged.
Normal Voltage: 2.5 vdc/ at 25 C ( plugged in )
Check Point:
1. Unplug the sensor on the indoor unit PCB.
2. Estimate the resistance of the sensor.
3. If the resistance of the sensor is 10 ohms/ 5 ohms at 25 C then the sensor is normal.
4. If the resistance of the sensor is - 0 - ohms then replace the sensor.
5. Plug the sensor on the PCB and Power on.
6. check voltage.
7. If voltage of sensor is 2.5 VDC at 25 C then the sensor is normal.
8. If the resistance is O or 5 Vdc replace the PCB.
Posted on Apr 07, 2015
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 01, 2015 | LG Heating & Cooling
I get a CH2 error message on my LG mini split what does this mean?
From the limited information that I could find on this item, CH2 is a temperature error.
Sorry I couldn't find out enough information to really be of any help.
Jun 09, 2011 | LG LS-L1210CL Mini Split Air Conditioner
I have an error code ch 61 on my LG system
Hi, Please open the front panel of the air con and look for the reset button on the electronic board, press it once. the system will initialize, then you will see all the LED lit randomly wait for a second then closed the front panel and test it. thanks
Apr 24, 2011 | LG LS-L1210CL Mini Split Air Conditioner
LG B30AWY fault code ch 12. air con unit not working. any ideas???
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Feb 07, 2011 | LG Heating & Cooling
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
CH 5
This is a Comms error, you may have had a power spike/voltage drop/power cut. Or a wire has been broken but this is unlikely.
I would suggest turning the power off at the indoor unit by the isolator, and also the power at the outdoor unit. leave off for 10 minutes, turn on isolator on the outdoor unit and then the indoor unit. Then start the unit up.
If the problem persists you may have a fault with the unit and a A/C contractor would be required.
This is a common call for LG equipment, i get it all the time.
all the best
Jul 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Heating & Cooling Logo
180 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
