Question about Amana Refrigerators
How many cu. Ft. Is the Amana TR21VW? - Amana Refrigerators
  • Amana Master
  • 473 Answers
The 21 in the model should be the cu. ft size.
Posted on Apr 02, 2015
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
aborcass
  • 2651 Answers
SOURCE: Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Posted on Nov 16, 2008
  • 30 Answers
SOURCE: CU FT
I couldn't find that info but it's sometimes on your model/serial tag inside the fridge. I'm guessing from the model # that it's a 15 cube.
Posted on Apr 28, 2009
SOURCE: How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
Posted on May 02, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
What is the cu. ft. of this model refrigerator Amana TZ21Q2L
Per my Manual , The Amana TZ21Q2 is 21.1 cu ft. and energy guide $69
Apr 02, 2011 | Refrigerators
What is the cu ft of this fridge
the tell the cu size ck the model # as its in the # like a amana model arb 23tbs / this would be a 23 cu ft unit hope this will help . mm
Jan 20, 2011 | Refrigerators
Take care
Jun 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Filter change
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Jun 01, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Refrigerators Logo
237 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
