Question about Garden
Lawn tractor runs for 3/5min. then cut's off it dosen't sputter like its out of gas just cuts off. changed plug,air filter, new gas ,oil sprayed out carb. it runs great until it cuts off???
  • 24 Answers
Probably need to change carb diaphragms and service carb. If you have left fuel in over winter it can damage diaphrams
Posted on Apr 02, 2015
Testimonial: "thank you will give it a try"
  • d culloo
    d culloo Apr 03, 2015
    just bought new carb 78.00 still doing the same thing
  • tomshaw Apr 03, 2015
    How do you get it to start when it cuts out.
    Top Expert:
  • Garden Master
  • 12,962 Answers
Try replacing the igniter since it appears you have a thermal issue.
Posted on Apr 03, 2015
  • 156 Answers
Lawn tractors often have a manual shut-off valve for the fuel. Be sure it is all the way open.
    Sergeant:
    Champion:
  • 294 Answers
Agree with Tomshaw. Also stop using ethanol gas (if you are) as this can damage diaphragms.
Have gas in oil - will not start
Gas in oil is usually a symptom of flooding, caused by a stuck needle valve or damaged float in the carburetor. But 65 hours is awfully "young" for this problem.
Jul 16, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Cranks up and runs fine ,then starts cutting out then runs fine and starts cutting out again
I am no pro but my suggestion to you is if you have changed your spark plug recently check the gap on it and make sure it is right and make sure is the right spark plug for it. Also check the oil if it is low the motor as it gets hot will start to sputter or if it has to much oil it will have an air lock and blow you Lhead gasket after a while. Another thing to check is the air filter to make sure it is clean and check the timing with this if you don't trust your self ask an repair expert for your brand of mower.
Apr 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower runs ok until i engage cutting blades then engine starts to cut out and backfire
Could be a few reasons for this..
First try a new spark plug, new gas filter, clean the air filter and check the gas line for cracks or leaks..
If the issue still exists - try spraying some carb cleaner into the intake while it is running in short controlled bursts..
Or the carb might need to be rebuilt.. If it sat for a long time - the gas in the carb will shellac and cause it to not work properly.. Or it could be a bad float in the carb..
Good luck..
Sep 10, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Craftsman lawn tractor 21.5 hp, model no. 917.272463. The engine starts well, but while running it spits and sputters every second or so, whether at idle or at full throttle. I changed the fuel...
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18.5 sears craftsman yard tractor won't run right
The fuel filter needs replaced or the carburetor needs cleaned.
Apr 07, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
