Question about Tablets & eReaders
How do you fix the weather on a Trio tablet's home page.
I cannot set the weather on the home page of my Trio tablet
How do i get my axs trio tablet out of demo mode and user terminated?
It happened to me also after I clicked on Trio Watchdog just to see what it does. Immediately I stopped the app and "removed" it, but although it disappeared from the App list obviously it was still hidden somewhere. Could not use SETTINGS to see it running and stop it because SETTINGS will not stay up also, same ....demo message.
The solution, for me, was to open the factory loaded App Permissions app and go to the startup section where I unchecked Trio Watchdog. I than rebooted the Trio AXS tablet and was back to normal.
May 24, 2015 | Tablets & eReaders
Tablet does not completely come on when activated.
mine either but ...... that means that your battery bar is not full even though it says is it.Or ur tablet does not hold its charge
Mar 20, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
I need the model number for my 10.1 tablet and it's not on the box.
Look in the settings page, probably under general, this will have all the details of your tablet such as model, serial number etc!
Jan 17, 2015 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth 10.1 is getting stuck on the@9 dual core load up screen. what do I need to do to get it to finish loading??
HI Naomi.
I do alot of TRIO fixes. Here is a great youtube walk thru. If it does not work I can try some other fixes but they can wipe out all your settings and data.
Good luck
Chadman TRIO 10 1 g2 Stealth Elite Android Tablet Update 2 Testing Recovery Mode...
Nov 24, 2014 | Tablets & eReaders
I have a trio stealth g2 10" and it was stuck on the start up (logo) page. I tried the hard reset (holding -volume and power button) and it worked for a day then froze up again. When I tried another h
I cases like this you might not have a choice but to factory reset to fix the start-up error. Repeat a hard reset (Vol up/Power button) and make an effort to get to the tablet Settings after boot up. Get to the Settings>Backup & reset>Factory data reset. In the majority of cases a factory reset will resolve critical issues. This is thought of as a "nuclear option."
If this nuclear option fails then a more complicated process that's beyond this post is to consider installing a custom Android ROM after rooting the device. XDA has a forum discussing rooting and installing custom ROMs for Stealth tablets: http://forum.xda-developers.com/showpost.php?p=34126848
Good luck.
Nov 20, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How do I get my trio to go back to the home screen?
It could be that your touchscreen (digitizer) is PARTLY broken.
To confirm, try rotating your tablet 180 degrees, and then touch the home button again.
If it works when rotated then you need a new touchscreen.
I hope you are good with precision tools, and have good mechanical skills and instincts: it's a rather intricate job to locate the locking tabs and screws that attach the touchscreen to the insides of the tablet, then remove them, and finally to replace a touchscreen. And then reattach all necessary fasteners, and test whether it will work properly.
EASIER FIX: go to Ebay and buy a used Trio tablet. it may cost you only $40 to $50 maybe even less!
Sep 27, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trying to download, Weather Bug App? Tablet says it's Downloading?
Sometimes the store app gets hung up. Go into Settings > Application or Application Manager. Locate your store app. Usually Play Store. Tab it and clear the data and cache. Restart the tablet and try downloading again.
Dec 08, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
76 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
