Model WDSR2080DAWW motor works but will not spin out clothes. It goes thru all the cycles, agitates and everything but will not spin the water out of clothes. The basket does'nt spin.
If I select small load, the machine does not fill.
  • Washing Mach... Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 13, 2015
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
