Ariel Platinum AM128, i am looking for the installation manual
Looking for a manual for 3.5qt. platinum classic model #pchc-25D
Hello, Rickco -
Your question landed in the Fixya.com category for Motorcycles. I do not find any motorcycle with the name "Platinum Classic" and the model number pchc-25D.
Instead I found information on a Platinum Classic pressure cooker Model # pchc-25D.
If I am correct that you really mean to ask about a pressure cooker, then . . .
I have looked and looked for a manual for model pchc-25D and have not yet found one to download from a website I consider safe. I also have not determined the website address for the company which manufactures (manufactured?) the Platinum Classic pressure cooker.
Best wishes.
Jan 16, 2018 | Motorcycles
Hi I have poor reception in my car. Not sure exactly where the booster or being a calais where abouts is the second antenna? I heard that they had a built in one in the rear window. Is that true?
They came standard from the factory with an electric ariel, The ariel was located in the LHS Fr quarter panel just in front of the passenger rear vision mirror on the door. not sure if they had the adjustable electric ariel which would have an up and down arrow button just on the deck or under wear the factory head units were installed. The biggest problem for reception is if they are not earthed properly against the car. if the antenna has been replaced theres a good chance someone may have stuffed up the installation. its best to take the front left tyre off and remove the inner wheel guard/surround so you can get to the ariel unit. from there the cable just runs through the firewall panel and behind the dash to the stereo. they are easy to pull through but make sure you know which holes they came through. when pulling new cable you should remove the glove box to. just pull one of the back corners to the center and it will pop out then the rest is easy.
To simplify things you could just install a manual ariel aswell (430) new electric ones may cost around $100 for a aftermarket one.
Jul 08, 2014 | 2006 Holden Commodore SS
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
I have an ariel whirlpool tub that has an E1 error problem
Have never heard of that error code. What brand of bathtub do you have?
Rod
www.uspartscenter.com
Jan 23, 2013 | Ariel AM156JDTSZ Platinum Corner Whirlpool...
Is there any way I can convert the Ariel crib into a toddler bed?It was advertized as a 3 in 1 but now that I am ready to convert it I don't think it is...maybe it only converts to a double bed??
Per the companies website (storkcraft.com) it doesn't look like the Ariel is a 3 in 1 but a 2 in 1. The manual is here
http://www.storkcraft.com/docs/all/04588-43.pdf
and it mentions converting to a twin bed, but not to a toddler bed.
Possibly put the mattress all the way down and remove the smaller side rail for a 3 sided toddler bed. Make sure the frame is sturdy enough without the 4th side.
Dec 22, 2009 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Need Help converting the Storkcraft Ariel Crib into a full size
Beats me. All the frames I am familiar with have brackets at the headboard end and open channels at the foot. Maybe Storkcraft can explain.....
Dec 24, 2017 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Tan wire above the fan
That sounds like your Wifi/Bluetooth Ariel loop. Some laptops have the ariel installed but no WiFi/Bluetooth module, This is so you can add it later if you want it
Oct 03, 2007 | Toshiba Satellite Pro 6100 Notebook
Televison & Video Logo
Top Televison & Video Experts
