Question about Canon MX882 All-In-One InkJet Printer
Remove ink absorber pads - Canon MX882 All-In-One InkJet Printer
holborn
  • 17 Answers
SOURCE: How do you remove the waste ink absorber pads?
no need to open the printer.....you only need to reset the counters. use canon reseter!!!
Posted on Feb 07, 2008
SOURCE: How to open Canon iP3000 and remove absorber pads?
my computer see the printer as ip3100 & ican`t load my driver
Posted on Mar 12, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 421 Answers
SOURCE: canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Posted on Nov 14, 2008
greg_margo
  • 1959 Answers
SOURCE: I need to override the ink absorber full message
This procedure will reset your printer. Thanks for using Fixya and please remember to return to rate this answer.
Greg
1. Turn off printer
Posted on Nov 27, 2009
My ink absorber is full on mx310
When the cartridges are parked, there is a pad that absorbs ink when the nozzles self-clean. After a while it gets full. Put the printer in the change ink mode to move the cartridges away from their parked position. If there is a plastic cover over the absorber, remove it. Then take a straight pin and pull the absorber pad out. Wash out the excessive ink and let it dry before reinstalling.
Dec 13, 2016 | Office Equipment & Supplies
How can I change the foam pad that absorbes ink? What part is that called?
Hello
Its better to just remove them clean them up and replace it in the printer, because usually some printers require a reset code to re-set the waste ink counter. If the counter is not re-set there will come a time when then printer will refuse to print.
Here is how to clean your waste ink absorber;
Open the printer and locate the waste ink absorber near the ink cartridge.
Remove the absorber pad and hold it in cold water while squeezing the ink out. It would be wise to wear gloves while doing this, because the ink in the pad will leave stains.
Use paper towels to dry the waste ink absorber pad. Let it dry completely before installing it back in the printer.
Reinstall the ink pad into the printer and run a test page to make sure it works.
Apr 20, 2011 | Epson Stylus Photo R300 InkJet Printer
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
1. Click Reset Main to reset the waste ink counter and
2.
Happy printing.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
My cannon printer/copy machine says my ink absorber is full. What does that mean? what do I do?
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges that collect the waste ink.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Oct 07, 2009 | Canon Office Equipment & Supplies
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Canon MX882 All-In-One InkJet Printer Logo
152 people viewed this question
old marine
old marine
