Question about Samsung Televison & Video
I have a Samsung 51in Plasma TV model # PN51D530A3F My volume UP button on TV quit working & my remote will not operate volume UP or DOWN..... Can someone help me ???
    Top Expert:
  • Samsung Master
  • 75,311 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts.
Posted on Apr 02, 2015
  • thomas lee Apr 02, 2015
    The remote is working fine.... Its gotta be the TV itself, any other ideas
How to program a vizio tv without a remote vizio
Upon first start you should be prompted. If not, you will find a series of buttons on the TV itself; power,channel up down, volume up/down, input and menu. Hit the menu button and the menu will pop up. Scroll up and down with channel button, select and controls are the volume. either that or you can get a Samsung phone that has an app built into it called watch on, which has a universal remote that works for virtually everything. Happy surfing.
Mar 05, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma buzzes
If the screen is cracked, the set is no longer any good.
Since a screen replacement is usually as much as a new TV, you might as well use your money for a new TV.
Nov 27, 2013 | Samsung PN51D530A3F
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
The volume will go to high by itself, and then decide to go all the way down, without touching the remote or the tv volume buttones.
The Samsung brand is the most universal remote compatible tv out there, sounds like either a neighbor or even someone in your own home has a Samsung product that will work on your plasma. for example if someone within range has a Samsung dvd or blue ray player the volume up and down button will work on the Samsung tv also.
May 30, 2011 | Samsung 50 in. Plasma TV
Hi,I have a Samsung plasma PN50A450P1DXZA that start to act crazy!! The remote it's not working at all (new batteries), but also the controls on the tv are not working, the volume bar stays on all the...
i did come across this problim, you gonna have to do the next step. unplug the button pc on tv that control youre volume,channels ext. but you gonne have to use youre remote to see if youre problem is solved. i run my tv only from remote, after this problem you got.
May 02, 2017 | Samsung 50 in. Plasma TV
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 25, 2009 | Samsung HL-S5086W 50" HDTV
Televison & Video Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
