Question about BLUE MAX 2-in-1 - 14"/20" Combination Chainsaw in Protective Case-
I HAVE A BLUE MAX CHAINSAW (BRAND NEW) AND i CANNOT GET THE EMERGENCY HANDEL TO GO BACK INTO THE RUN MODE. iT SEEMS STUCK AND WON'T MOVE. AM i MISSING SOMETHING?
I CAN SEE HOW IT SHOULD PULL BACK BUT IT IS STUCK. i CANNOT FIGURE IT OUT. IT IS BRAND NEW OUT OF THE BOX.
  • BLUE MAX Master
  • 2,760 Answers
If by emergency handle you mean chain brake ? are you pressing in on it (towards saw) as you pull back towards handle it's made to latch in chain stop mode on purpose
Posted on May 26, 2015
How to order gas line for chainsaw blue max 45cc model 6595
MAN, you MAY be in luck!
Checkout THIS obscure link!!
Chinese Chainsaw Parts
#75339 D24
GREY MARKET CHINESE 52CC - 58CC CHAINSAW FUEL LINE 75339 D24 NEW
Molded rubber gas line - NEW - Fits many Off-Brand Chainsaws made in China 45cc, 52cc, 58cc, SL4500, SL5200, SL5800, SL 4500 5200 5800 Falcon Pro, Forester, Kraftech, King Saw, Silverline, Blue Max, Yard Dog, Gio, Raiden, Talon, Powerhorse and...
75339 D24 75339 D24
Hope this is it!
Anthony
Apr 15, 2018 | Garden
Why is my 14 &20 chainsaw Model 8901/8902 having difficulty pulling cord. It seems to lock. What could be the problem?
if it runs ok after you get it started it could be the starter pulley. the blue max saws have that problem
Feb 10, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
I bought my husband a 2 pc. chainsaw set. Blue Max 14"-20" It will not stay powered up to make a cut, after it is started. We need to know where to take it for service, or what process is needed for a
A good idea to take it to home depot. Some of them have stations that work on fixing power tools and other things that break often. As for your problem it seems as if there is some sort of connection problem with the battery. Whenever you move it may jostle the connection enough to cut it off there for turning of the chainsaw. If you can check they battery and see if there are any loose cables that may help and if not take it to home depot.
Jan 29, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
I changed the chainsaw chain on my Blue Max chainsaw. The kick-back seems to be locked
Bob take the chain off again and remember to tighten the tensioning bar so that the chain is slightly loose. Enough to pull a few cm of the bottom just to stop it being tight.
Aug 30, 2014 | BLUE MAX 14" Chainsaw replacement...
I have a Lexus RX300 1999 model and have this recent problem. engine running normally but gear gets stuck in Parking mode and won't shift. had to depress the emergency button on the gear shift and
Some automatic vehicles rely on the brake switch (mounted on brake pedal) to be activated by depressing brake pedal. This signal then operates a relay and switch, to release the gear lever.
Firstly, I would check the brake pedal switch (are your brake lights working?).
If brake switch is confirmed OK, then inspect the relay (and related circuit components) of the gear release switch.
Mar 04, 2013 | 1999 Lexus RX 300
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw starts but chain does not move freely in running mode. flip the guard back and chain moves freely but will not cut because safety gaurd has been tripped.
1:the chainsaw have a emergency brake to reset pull the protection right in front of your hand over the saw 2:you need to check the oil sistem in the chain maybe the chain is dry 3:the chain is worn or a bad tension adjustment check this i hope this help to you
Dec 08, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
BLUE MAX 2-in-1 - 14"/20" Combination Chainsaw in Protective Case- Logo
302 people viewed this question
Top BLUE MAX Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a BLUE MAX Garden Expert? Answer questions, earn points and help others
