Question about Maytag Refrigerators
EXPLICIT DETAILS ON REPLACING FACADE ON MAYTAG REFRIGERATOR MSD2351HEB
2 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: My maytag refrig will make
Hi sir/madam,
Your control board is the problem
What voltage should it be?
You should have 120 volts.
You need a volt meter or a multimeter to check voltage.
The unit should be receiving 120 volts AC from the line.
Check that the wires from under the unit to the control panel are ok.Check you have any water marks on the board of the circuit lining.Check the shape of transistors edges.It should be properly shaped.It should not be melted or heated.
Replace the board alone.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 08, 2010
Can you replace the plastic cover on touch pad? One button is worn out.
The touch pad is not avail separatley, the conplete Facade/Escutcheon needs to be replaced. Part# 61005386 approx $160.00. In some cases the original clear plastic protective film might still be left on the front of the facade. Pleazer Appliance...
May 14, 2014 | Maytag MZD2766GES Side by Side...
Freezer works fine, fridge is not cold enough
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jul 19, 2011 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Refrigerator Side not working freezer working fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag MSD2351HEB 33" 23 Cu. Ft....
REFRIGERATOR FREEZER SIDE ICEING UP
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 25, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
My water and ice dispencer is not functioning is this because my water filter is clogged
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 08, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
How does cover on outside of door for ice maker dispensing come off need to check ice chute door closer
generally the facade is merely pressed into place, if you look closey to the underneath of the facade there may be some small indentations for a small flat blade screwdriver, if thats the case, with some downward pressure at the top of the facade, and a pry from underneath ti should "pop" right of, youll notice that the top of facade hangson to a few tabs and the bottom will need to be Popped back on geneally witha good swsift smck in the downward direction
Apr 22, 2010 | Refrigerators
Water and ice despencer
Production of ice cubes depends on freezer temperature. zero degrees turns out ice more often than 15-20 degrees. Slow water?
You may have a partial clog in the supply line to the water sloenoid vavle. Are the ice cubes normal size when dumped?
Jun 20, 2009 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Kenmore model 10657
yea it should pop off. look under facade trim should see 2 indentations for inserting a screw driver. care fully insert a flat blade and gently twist relaesing the plastic tabs, i find usefull to also push down on leading edge if dispensor facade(right above the indentations,
Jan 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
