Question about Polaris Ranger RZR 900 12-Volt Battery-Powered Ride-On
How do I check if the charger for the battery is working properly
  • Polaris Master
  • 2,963 Answers
Volt ohm meter should show 12vdc. Or you may be able to connect a 12vdc lamp to the charger connection points and see if lamp lights. Or disconnect battery, plug in charger and test voltage at the two battery disconnected battery cable ends.
Posted on Apr 02, 2015
I put new batteries in my Cobra 2-way radios and charged them for 24 hours. Still shows "low battery" when I turn them on.
Check your charger and battery contacts. Cleaning battery contacts on the radio and charger with a pencil eraser will remove dust, dirt, debris, and hand oil which may cause the battery to charge poorly. Secondly, you might want to check that your charger itself is working properly. If you have a second known good radio you might try charging it on the same charger.
Best regards.
Sep 28, 2014 | Cobra Radio Communications
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Hi my nokia n97 mini is not charging properly and isnt turning on either. i have two chargers for it. the plug-in wall charger is about 2 months old and i have an in-car charger which is about the same...
Make sure your battery isn't fully drained. Make sure your battery has at least 3.1 V. Anything above that is good. You can check this by using a voltmeter/multimeter
If the battery is OK, make sure both of your chargers are working. Both of them can be bad. You know, there is a posiblity.
If the chargers are fine and the battery is fine, it's probably a hardware fault. Hand it over to a repair shop
Jun 19, 2017 | Nokia N97 mini Smartphone
My laptop charging port is not working properly. My Charger is running properly but the charging port of the laptop is not working.It is not getting charged.Now the laptop is totally off and now i cant...
There are three possible parts of the computer which cause the problem.
1. ac adapter or charger
2. battery
3. motherboard
The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
Here's what you need to do:
1. Remove the battery from the laptop.
2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
Apr 19, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Light charger not working
This happens to me all the time. Check inside the charger and battery conection for debris. The battery you have may be bad or the charger may not be working properly. Most the time its the battery, either its too hot or too cold when you go to charge.
Mar 05, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Have a Sony DSC-S75, digital still camera. Camera still works with a new battery, but the charger doesn't recharge the battery anymore. Any fixes to this?
Hello
The charger might gone bad too, check the charger as well, it is quite possible that your old battery was also not dead. the charger could not charge it properly,
Hope it helps
Dec 21, 2010 | Cameras
I have a 12V Peg Perego battery charger. I think
yep check it with a multimeter and it should show between 12-14.6 volts
May 08, 2010 | Peg Perego 12 Volt Rechargeable Battery
How to correct low battery?
when it says low battery mens you have to charge your mobil otherwise it get switch off
Apr 04, 2010 | GE Telephone pr521w
The radio is not charging has new battery
Check your battery contacts on/in the radio, battery and charger. Clean with a pencil eraser if needed. If your charger will accommodate the battery alone, try charging the battery outside the radio. Does the charger's light (if any) come on and stay on when the battery/radio is attached? If so, your charger is working properly. If the light (if any) on the charger is flashing you may have a shorted or bad battery. Check your user guide to the radio/charger for more information. Finally, periodically a battery has too low of an initial factory charger to start charging on the charge immediately. Try placing the battery on the charger for 3 complete charge cycles, and see if it will then charge. If the battery is new, you might want to contact the vendor for a replacement.
Aug 22, 2009 | Yaesu Radio Communications
Battery
Most likely the battery.
Sep 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Polaris Ranger RZR 900 12-Volt Battery-Powered Ride-On Logo
738 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
