Question about JUMP START SYSTEM
How do you recharge the system - JUMP START SYSTEM
  • 987 Answers
A/C system????????????
Posted on Apr 10, 2015
    Scholar:
  • 138 Answers
What kind of battery are you asking for? Get yourself a good battery charger and follow the directions found in the box. It will explain everything you need to do.
Posted on Apr 07, 2015
2000 cadillac deville recharge ac how to
Melvin, Recharging a cars A/C system. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Right Wrong way to recharge AC
2003 Escalade charging AC
How To Recharge an AC System EricTheCarGuy
How to Properly Recharge Your AC System
Jun 19, 2016 | 2000 Cadillac DeVille
Vw eos aircon recharged but still not working
In order to recharge the A/C you have to have the car running and it will take two people to do it or you will ruin the system. You recharge the system with someone sitting inside of the car(while running). If at any point in time you only get a partial recharge, you have to empty all of the fluid out of the system and start over again so you do not ruin your A/C Condensor(because it costs about 300 bucks).
Jul 28, 2012 | Air Conditioning and Heat for Volkswagen...
We need to know exactly what type of connector is needed to recharge a Coleman 1,500 camper AC.
Usually a recharge connector or "saddle valve" is brazed onto the suction line for recharging the system. The system leak obviously has to be corrected and the system must be pressure tested with nitrogen before vacuming the system and ultimately recharging it.An A/C system operates in a vacum and if there are contaminants or a leak it will not work properly. I'm not being facetious here, I just don't know how much you know about A/C systems.
Aug 03, 2011 | Coleman Heating & Cooling
I have not recharged a system in a while. If the system is out of freon will the compressor still turn to pull in the refrigerant.
It should take the freon . Compressors will actually pull a vacuum if the refrigerant
is completely exhausted. You should be able to recharge system if the unit is just low
on refrigerant.
If no pressure is in system, I would have the accumulator replaced and
have a vacuum pulled on the system before recharging it. (The accumulator has a
dessicant/ filter in it and may become clogged if the system is empty)
The vacuum is to boil off any moisture in the system
from having it open and also to check for leaks. If moisture enters the system because of a leak then it can freeze in the metering
device when the system is recharged. I hope this helps.
Jul 23, 2011 | 1999 Buick Regal
How do I recharge the Air Conditioning?
A simple recharge on a system that old is usually wasted money. There are several components which may have reached the end of their service life. Best thing is to have a good tech check for
leaks and functionality, if all is good then recharge. Otherwise you may find that the system is not working a few days after the recharge.
Sep 07, 2010 | 1994 Buick LeSabre
I have a 2002 pt cruiser and my ac is not colling
Your car ls most likely low on refrigerant. If you're handy, you can get a recharge kit at an auto parts store to recharge your AC system. If not, most service stations will recharge the system for under $100 but be aware that they are mandated by law to detect any leaks prior to recharging the system. If a leak is detected, they must repair the leak prior to recharge which would lead to a more expensive repair. Best of luck.
Greg
Jul 07, 2009 | 2002 Chrysler PT Cruiser
My ac wont work... and it just quit working... and everything still works... is it the relay switches??
Check the fuse first to the A/C to make sure it's has not blown. The other thing to is the system may be low on R143a. If you not to familiar with recharging the system you can take it most shop now and have it serviced. Call around first for the best price to recharge the system. You can buy a recharge kit for around $50.00 but that's around the same price to recharge the system and you don't have to worry about over charging the system causing damage. The recharge kit can be bought at Wal Mark or any large parts store like Auto Zone. Here is a link on how to recharge the system your self if that's the method you wish to go. Good luck and hope this helps, Keep me posted. be glad to cool all summer. http://www.cyberbright.com/autobin/air_conditioning.htm
Jun 24, 2009 | 1997 Pontiac Bonneville
How to recharge the ac
reclarification. I will need to know what type of vehicle it is. Secondly, do you have the equipment to evacuate and then recharge the a/c system?
The system must be pumped down to 20 inches of vacumn for at least 1 hour before recharging the system.
This operation is highly regulated in most states now because of EPA issues.
Bill
Nov 19, 2008 | 1993 Mercury Sable
How do I recharge the a/c on my 95 jeep GC?
If the AC is not blowing cold air anymore, then yes, recharging will help. However, the AC system is a sealed system and should never need recharging. So if it does need recharging, then there is a leak in the system somewhere that has to be fixed first. It can be a little pricy, so be sure to call around for quotes.
Jul 11, 2008 | 1995 Jeep Grand Cherokee
JUMP START SYSTEM Logo
228 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
