Question about Dishwashers
Will not suck the detergent out of the container
Suck hoover
If the wire is underneath the unit it won\'t suck up the water. I did this once. Make sure it is flush with the floor.
Nov 11, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
What do these lights mean there not going off
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in
dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water
softener. Only fill with salt just before starting one of the washing
programmes. This will prevent any grains of salt or salty water, which
may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse
aid dispenser with any other substances (e.g. dishwasher
cleaning agent, liquid detergent). This would damage the
appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
Hobart CHF 40 dishwasher water coming back into container and flooding
You don't need to use regular dish detergent. Use dish washer detergent. Check seal around door also.
Mar 03, 2013 | Hobart Dishwashers
Detergent not sucking at the time of washing.
When the detergent is not sucked by the washing machine it is usually because the detergent has dried in the check ball and spring area of the dispenser.
Unscrew the fitting the inlet tube attaches and takes the spring and ball out. Clean the dispenser area and the ball and spring. Reassemble and it will usually work.
Hope this helps.
Shane
Feb 20, 2011 | LG WM1812C Front Load Washer
Hi ive got a karcher k.3150 ive only had it 2 months and ive gone to use it the 3rd time and the detergent is not coming out of the container and ive done all checks-blockages etc and dont know why its not...
This seems strange, as it is under warranty you can take it back or contact them about the situation. It depends were you purchased the machine but if it is a manufacturers fault they will fix/replace it.
Jan 10, 2011 | Karcher Garden
Detergent container will not despense fluid
Check that the switch is on autowash and not just on the rinse option. I see that customers do this alot.
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Jun 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Owen Barnes
