Question about Honda GCV160 Engine
If I have fuel in the cylinders post fuel in my filter and exhaust caused by sticking float, will this prevent me from pulling the cord?
I stripped the carb down following fuel in filter and exhaust and checked the float in the float bowl. I have now reassembled it and am unable to deploy the cord. It is very stiff. I was initially able to move the blade slightly but now nothing is working.Is this due to fuel in the cylinders? When I took the spark plug out there was fuel everywhere. If it is how do I get the fuel out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
You are absolutely right on target. This is called 'hydro-locking, In fact many engines have been destroyed when a leaking fuel injector ,overnight, even partially fills a cylinder that is on compression stroke. With the higher cranking speeds today, It usually bends the connecting rod when the engine rotates 1/4 revolution s or more and 'hits' the in-compressible liquid.
In your case, simply remove the spark plug, and pull the rope a few times to blow out the gasoline and then add a teaspoon of oil in the cylinder, pull the rope a few times to re-lubricate the cylinder. When there is no liquid coming out, reinstall the spark plug and it should be good to go.
With carburetors, even a tiny speck of leaf or grass can cause the float valve to leak.
Posted on Apr 03, 2015
  • julie Perry
    julie Perry Apr 03, 2015
    I have tipped the endine on its end with the spark plug out and left it in that position for a couple of hours and no petrol has come out. I cannot pull the cord at all. It is solid and this is what has annoyed me becasue when fuel started coming out of the filter the cord pulled freely, so it wasn't lackof oil but I think fuel has got into the cyliners and damaged the engine. I have put penetrating oil in the spark plug hole and left it over night, so I am going to see in aminute if it works but I shall not hold my breath. I am annoyed that a simple thing like fuel leaking can cause so much damage. I wouldn't mine if I didn't look after it but I do which makes this even worse for me.
  • Honda Master
  • 2,963 Answers
Sounds like you got a huge amount of fuel in the cylinder. I'd tilt the engine up with spark plug hole open and down. Leave open overnight. Next you Must change the oil. Fuel is in the oil and may destroy the engine. You have probably "washed" all the oil off the cylinder so it is difficult to move. Leave the drain open overnight.
Posted on Apr 02, 2015
Testimonial: "Thanks for the advice."
  • julie Perry
    julie Perry Apr 02, 2015
    I have drained the oil off and I have also tilted the machine but no petrol has come out of the spark plug hole at all, not even a drop. I could leave it overnight but I was expecting it to drip out. The spark plug has been off for sometime. The blade underneath is solid and not moving. Someone has told me that it would have damaged the engine anyway all because of a float sticking. Seems rather a bad bit of design to me.
  • gbob59 Apr 02, 2015
    Before throwing away I would spray a good amount of WD-40 or equivelent in the spark plug hole. It may free up the piston and get some lubrication to the piston.
Have K341s engine on a welder and crank case flooded with fuel. what should I look for?
It is likely that this engine has a gravity feed fuel system such as the lawn tractor in the photo. The problem is if the needle valve sticks open, float fails to push the needle into the seat fuel will flow until the tank empties. The fuel floods the engine and leaks by the valve stem and cylinder rings filling the crank case with fuel.
What a mess and always a concern when fuel leaks. The preventative is to make sure the fuel shut off valve is closed when engine is not being used. Usually running the engine with the shut off valve will empty the carburetor of gas a good procedure to prevent the carburetor from fouling.
You must drain the oil completly and replace before running the machine.
Likely with the engine vibration the needle will operate normally. Removing the bowl and checking for contamination is recommended.
Adding a new filter and confirming the fuel shut off is working is also recommended.
2set-float-valve-needle-seat-kit-for-briggs-stratton-398188-281144-kit-font-b-5-b-o2aflg0ryfegd3pfpl5qlmia-5-5.jpg
Jun 29, 2017 | Cars & Trucks
Lawn mower following fuel in filter and exhaust and checking the float and reassembling the carb the pull cord won't deploy
Hi Julie,
There's a penetrating catalyst (oil) called "BLASTER". Anything that may be causing the engine to freeze up, that can be desolved, broken loose or washed away... This stuff will get it done. You can get it at any auto parts store. Try that in the cylinder.
Also, Try back tracking what you've done. If the engine began acting frozen after you installed the carb, take the carb back off and see if the engine will turn over without it. If for some reason air doesn't flow through the carb, the engine will appear to be frozen and won't allow the exhaust valve open to complete the cycle.
Let me know what happens. I'm interested to find out. Have a good morning,
Bill
Apr 02, 2015 | Gcv160 Gas Engine
Following fuel leaking through the air filter and exhaust and checking the float bowel & putting the carb back I cannot engage the cord. The break is deploying and was working prior to the fuelleakage
remove spark plug and try it if gas blows out you have a carb problem rather sounds like the fuel has leaked and filled the cylinder . means float is sticking in the carb .
Following a leak of petrol in air filter and exhaust and checking float bowl, now cannot pull the cord to start it. Checked blade it was going round but not now. Cleaned debris. Could it be linkages?
Try removing the spark plug first then pull the cord while spark plug is out. The cylinder may be full of petrol, preventing it from moving.
Once the cylinder is free of liquid, you can reinsert the spark plug and try again to start it.
Apr 01, 2015 | Honda GCV160 Engine
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
My pull cord on my Stihl gas backpack won,t pull out unless i have taken out thesparkplug
This tells me the cylinder is full of gas from needle sticking open in carb,causing it to siphon fuel in from tank when shut off, a bad cap or fuel vent will also cause this. need to tip upside down and pull rope several times with spark plug out to get all the fuel out of crankcase/and cylinder....This is causing hydrolock.
Oct 31, 2011 | Garden
Gas is spitting out of the exhaust
Check your oil. If it is too full , change it. Occasionally the Honda's of that time would have the float stick and fill the engine with gas. There may actually be nothing wrong with your cycle , new bikes did this. If gas filled the cylinder and went into the exhaust you probably have a stuck float. If the problem happens again you may have to disassemble and clean the carburetors , replacing the float needles at that time. One good way to keep your oil from filling with gas is to always turn off your gas at the fuel petcock after riding. Be sure to check your air filter for gas/oil saturation and be sure to pull the plugs on your pollution tubes under the air box to drain the blow by.
Oct 23, 2010 | 1984 Honda VT 500 C
My engine exhaust smells like raw fuel
Most Goldwings smoke if you park them on the side stand. I always use the center stand, Like wise if you have a stuck float or a bad float needle gas will run through the cylinder and out the exhaust valve into the muffler if you do not shut off your gas when not riding. This would cause raw fuel in the exhaust. If leaking on the center stand, more gas ends up in the oil. Check to see if you have more oil than you should in the crankcase. If you do change your oil . If this happens all the time you probably need to rebuild your carbs and change your fuel filter.
Jun 30, 2010 | 1985 Honda GL 1200 Aspencade Gold Wing
Hi i was riding my yamaha yz125 2001 and it cut out now it doesnt have bareley any compression what so ever ! IT WILL NOT START PLEASE HELP :( WHAT DO YOU THINK THIS IS ?
make sure the float did not stick open and flood the cylinder. turn off fuel supply and remove exhaust pipe from cylinder. Does expansion chamber have fuel in it? It shouldnt- drain it. Place a towel over rear of front fender and on floor under exhaust port and kick motor over. Does fuel spray out? If so motor is severely flooded. Keep kicking untiul all fuel is purged from motor. Motor will likely start and run for a second once the fuel is reduced to a level the motor can handle. Reinstal exhaust and fix carb/ float problem. Hope that solves the problem.
Nov 23, 2009 | Yamaha YZ 125 Motorcycles
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
Open Questions:
Help! Why wont my lawnmower start? I am sorry to keep posting about my blasted lawnmower but quite honestly I am baffled to why I am having so much trouble with it. At the beginning of the season I had fuel seeping through the air filter and on one occasion it nearly caught fire. I took carb off and cleaned it and checked the float and pin and it all seemed to work perfectly find. It still leaked when I put the carb back on, so I had it professionally cleaned and they checked the float and pin and said the same that it was okay. I put it back on the engine and it leaked petrol again. I bought a new carb and put it on and it went like a rocket and I was very pleased. I ran the machine for over two hours no problem at all. Two weeks later I get my mower out and it won't start. It won't even turn over. I went and bought a new spark plug just in case but nope it still won't start. Before you ask, yes I did turn the fuel on and engage the choke, so I am at a loss to know what is wrong with it. I know gas, air and spark are the three ingredients that make an engine work. It has had a new filter, spark plug, gaskets and carb this year and an exhaust last year. Someone mentioned it could be the coil. Is there anyway of finding out if this is the case. It just seems everything is going wrong with this engine at the moment. It is 11 yrs old and has been looked after but I don't understand why it went for over 2 hours and cut beautifully to not turning over at all. Any help would be appreciated. Many thanks
Sep 01, 2015 | Honda GCV160 Engine
Honda GCV160 Engine Logo
74 people viewed this question
Top Honda Tools & Hardware - Others Experts
John Loiselle
Level 1 Expert
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
