Question about Kenmore Dishwashers
Kitchenaid, Kenmore Dishwasher Pops Open During Cycle
I wanted to add an answer to this question: w.fixya.com/support/t1514171-kitchenaid_dishwasher_door_pops_open however it looks like it has been closed to new answers. Given the sheer number of ideas and answers I thought it would be good to give a summary. It appears as though Kitchenaid and Kenmore dishwashers are similar, if not identical, so this advice should apply to several models out there. In brief, the door will pop open mid-cycle. You may close the door, only to have it pop open again immediately. Putting a chair in front of the door or some other elaborate retention device will allow the cycle to complete as normal. First off, here is a list of quick, easy, and inexpensive things you can try, although they did not personally work for me. WHAT TO TRY FIRST 1. If a Kitchenaid dishwasher specifically, there is apparently a handle on the front of the top rack. This can protrude enough to put a bit of pressure on the door. You may need to ensure the top rack is fully pushed back, or somehow reshape/adjust the handle. 2. The dishwasher may have adjustable height on the top rack. If so, many have found that it can slope forward, putting pressure on the door. As a test, lower the top rack fully, which should level it out. 3. While I doubt this is the source of most issues of the door popping open, certainly crud stuck along the door seal, and an improperly fitting seal can prevent the door from closing correctly. However, I might also expect leaks in this case. In any event, it will cost you nothing to quickly clean the door seal, and ensure it is seated properly. 4. If like our machine, at some point a door spring will break, and the door will be very heavy. In some cases it may slam right down. You must address this issue first, as there is obviously a lot of pressure on the latch assembly. The door must be neutrally balanced, so that it will just remain in any position you leave it in. Obtain a spring kit to resolve this problem first. 5. Among the first answers in the URL above was about loose door screws. I certainly had some loose screws in my door, but tightening them didn't help. I'm not sure how the loose screws would affect the door popping open, but no harm in checking the inside screws. You'll need torx bits though. Now, a list of things that I would avoid spending money on just yet. DO NOT BUY THE FOLLOWING: 1. While it might be the issue in some cases, do NOT buy a latch assembly. This is a larger, plastic, relatively expensive piece that has wires connecting to it. The electronic aspect of this assembly allows the door lock to actuate. So, if for example, the door is NOT opening, then it may be the resolution for you. However, it does not appear to be the solution for a door popping open issue. I bought this part for nothing, and wasted my money. 2. Door seal kit. Again, this could certainly resolve a leak issue at the door, or perhaps if an old seal was simply preventing the door from closing fully. However, I'd stick to just cleaning and reseating the seal for now until you've tried the easy stuff above, and the FIX... THE FIX In my case, after trying all of the above, and buying unnecessary parts, it was ultimately the door strike that resolved the issue. It is easily removed for a look, and there is at least one video on youtube about it. You only need a screwdriver, and needn't undo anything else, aside from pulling the dishwasher out a bit from the counter. In my case, the strike was bent unevenly, and after some trial an error I ultimately found a shape that held the door for a complete cycle. It also seemed to allow the door to close a bit easier. In some cases you can try to bend the strike without removing it, but that may not be ideal. You can also buy a new one if yours is damaged for a reasonable 18 USD. I spent hours, and a lot of money on this issue, so wanted to offer up a summary. Hope it helps someone out there, and I thank all of those who offered up answers in that other thread.
    Champion:
  • Kenmore Expert
  • 220 Answers
Sorry you had to go thru such agony in the near future call whirlpool the parent company they would have advised a new door strike technicians are privery to service bulletins and door popping open is one of them
Posted on Apr 07, 2015
How do I reprogram the start, rinse cycles? snowflake is blinking and nothing happens when I try to start washing.
[PDF]Download Bosch Dishwasher-Manual - DASH Property ...
www.dashpropertymanagement.com/.../Bosch-Dishwasher-Manual.pdf
Lift tab to open the rinse aid reservoir and add -3 tablespoon max, do not overfill. "qUid rinse aid ... Cancelling a cycle I Reset the dishwasher. 0 LEDs flashing ...
[PDF]Dishwasher Use & Care Guide EIDW6105G - Datatail
media.datatail.com/docs/manual/40243_en.pdf
We view your purchase as the beginning of a relationship. ... Store dishwasherdetergent and rinse agents .... This cycle allows you to program your preferred.
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
https://www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR
KITCHENAID DISHWASHER REBOOT ... Dishwasher Repair will not start - Repair & Diagnostc - Kitchenaid - Whirlpool ... What toDo When the Dishwasher Won't Start - Duration: 5:43. by doityourselfstan 217,315 views. 5:43 ... KitchenAid & WhirlpoolDishwasher - Not Cleaning ,pump wash arm impeller ...
Dec 16, 2015 | Dishwashers
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Kitchenaid dishwasher soap dispenser will not open during cleaning cycle
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 24, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Small amount of water leak during run cycle
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Jun 05, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
May 27, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kitchenaid dishwasher won't drain someone opened door during cycle will this cause a problem
Opening the door wont matter. If you stop the cycle during a run it will always go into a drain. You might have a plugged drain line or burnt drain pump..
Apr 04, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Kitchenaide dishwasher latch will not stay closed. It pops open during washing cycle and the machine stops and does not complete the cycle
The dishwasher was not properly leveled on installation. I used a carpenter's level
and trued up the problem. The door now stays closed.
However, the latch design is faulty in that it does not ever feel securely latched and that is true of all the Kitchenaides that I tried in the showrooms.
Jul 19, 2008 | KitchenAid Dishwashers
Dishwashers Logo
90 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
