Question about Sewing Machines
When making buttonholes, the machine will not zig zag in reverse when doing the right side of the buttonhole.
It will zig zag a little, but then it sews a straight line, and may zig zag a little more. It is sporadic. It does fine when zig sagging a forward stitch.
  • Sewing Machines Master
  • 627 Answers
1. Remove the top.
2. Clean the inside with carburetor cleaner and lubricate with sewing machine oil.
3. While After this move the stitch length back and forth from a long arm to the reverse mode. Rotate the hand wheel several times to lubricate all moving parts.
4. Place some rags under the pressure foot and watch if the rags will back up.
5. Remove the bottom of the machine.
6. Clean the bottom moving parts and lubricate.
7. Rotate the hand wheel and watch the feed dogs to see if everything is moving.
8. It is possible to notice a screw attached to the stitch length adjuster that will have to be tightened. This may require you to move other parts that are attached and apply pressure while doing this.
Posted on Apr 03, 2015
Hi I am wanting to do a 4cm buttonhole on my Elna Elina 40. The automatic button hole only goes up to 2.5 cm. How do I do a button hole as long as 4 cm please.
Just stitch the buttonhole without the automatic buttonholer. That's how we do it with machines that don't have the buttonhole function. Buttonholes can be done on any sewing machine that has zig-zag capability. A left/right needle position would be helpful, but if that is not available, just be sure to sink the needle into the fabric BEFORE changing the zig-zag width.
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Buttonholes without using special feet or cams YouTube
Feb 11, 2017 | Elna Sewing Machines
It does not have 4 steps to do a button hole and will only stitch on the right hand side when I put it on the button stitch. How do I do the end pieces and the left hand side?
You can perform all the steps of a buttonhole without the buttonhole option (ask how sewists used to do it before sewing machines offered the buttonhole option). You'll just need a machine that can zig-zag.
Making Buttonholes Without Special Feet
There are a lot of web sites and tutorial videos available.
Jan 22, 2016 | Sewing Machines
Auto buttonhole not working on manual setting
Could be a worn cam, but more likely a dirty or dry machine.
Jan 04, 2014 | Kenmore Sewing Machines
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Jan 30, 2013 | Husqvarna Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Auto buttonholer problem singer 2662
You do need to adjust your stitch length to get the satin stitch look. Also, some of the auto buttonholers require you to reset the lever after each buttonhole to restart it.
Feb 01, 2009 | Singer 2662
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
77 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
