Question about Health & Beauty
CAN I GET REPLACEMENT COMBS - Health & Beauty
On aquatic shaver do I replace just blades or screens also?
Replacement heads for Philips Norelco Aquatec shavers can be found at shaveroutlet.com. The replacement includes the 3 cutters and 3 combs
Norelco Philips HQ8 Spectra Sensotec Precision Replacement Heads
Nov 03, 2015 | Norelco PowerTouch Aquatec Razor Wet & Dry...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
I need replacement comb guards for model fx686x
I will sell you all of my combs guards for 25.00 plus shipping. My email is phpena@austin.rr.com.
Sep 18, 2012 | Health & Beauty
My shaver turns on but it immediately makes a click and stops, and then the light turns red. If I open up the top and turn it on, the three shafts turn at what seems like a normal speed. I have tried...
The heads are either damaged causing the blades to lock up or it is clogged up to the point that they can no longer turn. Inspect the outer combs for damage. If damage is visable, you will need to replacethem. You will find replacements for 7775X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
If no damage is visable, take the blades out and thoroughly clean them. You can soak in rubbing alcohol to help break up any greasy build-up. Once cleaned you should be able to turn the blades inside their combs with your fingers. If any of them snag you will need to replace them
May 16, 2011 | Norelco Cool Skin 7775X Electric Shaver
Hc 820 replacement combs, remington has discontinued them!
Ask your friends for spare.If not buying a new brand is the solution
Jan 05, 2011 | Remington Precision HC-820 Hair Trimmer
How to get remington hkvac 2000 replacement combs?
replacement combs can be found on amazon for good prices (from proven sellers.. take a look on reviews). take a look:Amazon com remington combs. I hope this was helpful. cheers
Dec 13, 2010 | Remington Health & Beauty
Not sure,but is the screen supposed to spin or not? 2 of the 3 blade screens spin,is that normal? Should they all spin,or should none of them spin? From what I can tell,all actual blades are spinning...
The combs (screens) should not spin. They need to be stationary so the hair can most effectively poke into the slots to be cut
If yours are spinng, either they are not put in correctly of they are damaged and need to be replaced. To check for damage, take them out and try to turn the blades inside the combs with your fingers. The blades should turn freely inside the combs. If they stick, they are damaged and need replaced.
If you require replacements for model 4401LC, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/specials/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Sep 26, 2010 | Norelco Micro 4401 LC Electric Shaver
Need a replacement head unit
In the UK, philips norelco HQ9 replacement heads for electric shaver philips hq9190 blades replacement parts
Jun 18, 2010 | Philips SmartTouch-XL HQ9190 CC Electric...
Health & Beauty Logo
241 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
