Question about Bosch SHV46C03 Built-in Dishwasher
Motor runs with door open. No water in pan. - Bosch SHV46C03 Built-in Dishwasher
    Habit-Forming:
    New Friend:
  • 20 Answers
Sounds to me like there may be water in the moisture sensor. Your dishwasher is probably leaking and the noise you hear is the drain pump activated.
Posted on Apr 12, 2015
    Habit-Forming:
  • 102 Answers
Even if there is no water in the base pan you should check the water sensor - a float located in the base pan, directly behind the water fill valve. Even if something (mouse, bug, etc.) other than a leak has caused this to move, it can force the control to shut down all operations and run the drain pump continuously.
Motor runs with door open. No water in pan. - 25623332-yxrp4l2ueh3uikfytgwmph0z-4-0.jpg
Posted on Apr 16, 2015
Drain Pan fills and overflows. Cannot get to drain pan to empty. Why the water and how do I get to the drain pan ? Also the refrigirator door maes a loud sound when It's opened and closed. It seems to...
The water is normal....however the evap motor and fan should be drying the water before it overflows. THe evap fan motor may need replaced. You will have to pull the unit from the wall and take the back panel off or tilt the unit back towards the wall and go in from the underneath side. As far as the door goes....you might need to tighten or replace one of the hinges.
Sep 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
My bosh shu33a06uc dishwasher is stuck in water discharge cycle. It will run untill door is open.
This error means your dishwasher has water in the pan below your tub. You need to remove toe plate below the door and soak up the water in the pan to reset the motor.
Good Luck
http://www.appliancerepairlesson.com
Mar 06, 2011 | Bosch SHU3306UC Built-in Dishwasher
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Why would water leak from the bottom of my GE refrigerator at least twice a day. Cannot ever locate the source and the water supply to the ice maker has been disconnected. That's another thing, The auger...
1. The water pan under the refrigerator is full.
This catches water whenever the freezer defrosts. Generally, the pan water evaporates and doesn't leak; however, the vents must be covered or something.
Pull of the bottom cover under the door and slide the water pan out. Empty it.
2. The motor nylon gear is broken. It is supposed to break in case a hand / finger gets caught inthe mechanism. It must have iced up and broken. It can be fixed.
Sep 21, 2009 | Refrigerators
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Won't fill with water
Bosch dishwashers typically have flood sensors in the bottom, below the motor. If there is still water in the pan the machine will not fill with water and only try to run the drain pump. Be sure there is no water in the dishwasher pan
Dec 02, 2017 | Bosch Evolution 800 SHE68M05UC Stainless...
Motor runs when door is open- water does not come in- seems stuck
depending on the brand and mdl the unit may be equipped with an overflow safety. If ther is water under the dishwasher in the floor pan then the sensors will trick the dishwasher into thinking it is leaking. Check under the kick plate . if it is moist then take a hair dryer and dry it up up until there is no moisture at all. This should cancel out the pump command and you can start over .
Jun 13, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Dishwasher motor runs (even with door open), but no Water
I believe the problem is in the electronic board. It is getting a different signal thus not allowing it to run properly. You can have a local service technician for the company look at it but this is probably the cause.
Dec 25, 2008 | Bosch 24 in. SHX46A05UC Built-In...
Bosch SHV46C03 Built-in Dishwasher Logo
212 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
