Question about Krups EA8250 Fully Automatic Espresso - Black
Coffee Machine refuses to finish auto-test, leaks nearly half of used water, after repair incorrectly connected pipes
Yesterday my dad tried to repair the coffee machine without success after the coffee machine had leaked too much water nearly half! when finished making the coffee. After that the problem escalated into the point of machine refusing to even properly start being stuck in Auto-test. In addition I am under suspicion that my dad connected the water pipes incorrectly. Here are pics of the pipes of which I am afraid they are incorrectly connected. The water seems to leak underneath the waste water bowl https://www.dropbox.com/sh/1g66lzro3j1itrn/AAAhpuJ1i3r_C4gxusB_aCmca?dl=0
5 Suggested Answers
SOURCE: fill out water
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
Posted on Jan 09, 2009
  • 474 Answers
SOURCE: When i push the oblong button to grind the coffee,
Sounds as if you may have had a spill of something sticky in the switch. Try taking the switch out and cleaning it.
Posted on Feb 20, 2011
SOURCE: During a cleaning cycle my krupa ea8080 bean to
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Posted on Mar 26, 2011
SOURCE: the water leaks out of the water bowl ,if not in use i have to keep it empty
try lowering the presher.
Posted on Jul 26, 2012
Steam pipe not working
to me the pipe is blocked there is a tool to use to clean this pipe out, hard deposits in the water can block the steam pipe and the tool is a thin bendy wire that you put up the pipe to clean the pipe line out. i would think they sell this pipe in most out lets for coffee makers. check for coffee steam pipe cleaner.
Jun 30, 2017 | DeLonghi Coffee Makers & Espresso Machines
Cuisinart brew on demand coffee maker
what about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
Aug 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Yesterday, my Keurig was giving me trouble with the menu, but it still made my coffee. That was the first time my coffee machine has ever given me trouble over the nearly year and a half I've owned it....
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Jul 05, 2011 | Keurig Elite B40 Coffee Maker
I have had this coffeemaker for about two months and use it daily. Yesterday the machine refused to make coffee, it would perk and perk but very little water came through into the coffee pot. The self...
We had the same problem and it seemed to be caused by the little charcoal filter. We took it out and the machine worked fine. replacements are available, but expensive. (2 for $9.95)
Dec 03, 2010 | Cuisinart DCC-1200 Coffee Maker
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Gaggia Classic - water not flowing
Remove the screw and shower in the group, then press the brew button, if water flows then clean shower. I will send instructions for descale and backflush. Cut time for backflush by half.
Dec 09, 2008 | Gaggia Achille lever operated espresso...
Water leaking from bottom. what's up?
the best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Jan 16, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco S-Class Incanto de luxe coffee machine not working.
If it is what it sounds like to me I had this same problem with a split pipe on my saeco vienna machine. The place tried to say I had not descaled the machine 4 times in under a year leading to the pipe bursting. This is what wrecked my machine but it could be a simple case of a hose blew off. Sounds like an internal fuse also blew. It should really be check out and should or could still work again once dry.
Jun 11, 2007 | Saeco Incanto Coffee Maker
Krups EA8250 Fully Automatic Espresso - Black Logo
263 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
