Question about Garden
Why is my Briggs and Stratton mower dragging? It won't turn over fast enough to start
  • 1,169 Answers
If it is an OHV engine the valves are needing adjusting normally as the decompression system quits working causing high compression at start-up speed.
Posted on Apr 02, 2015
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
freetek
  • 5568 Answers
SOURCE: briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Posted on Aug 20, 2009
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
  • 15 Answers
SOURCE: i can get my briggs & stratton push mower to
change the primer bulb it got a air leak.but firstmake sure the plastic tube going down in the gas tank with the screen on the bottom is not stopped up.
Posted on Jul 17, 2012
  • 6468 Answers
SOURCE: how do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Posted on Jul 19, 2012
Sarter will not turn engine over
Two things cause this...a bad starter or weak battery...not sufficient Amps will not allow enough power to the starter to spin it fast enough to start the engine....a bad starter simply cannot use the power supplied it to turn the engine properly. Have some one do a load test on the battery..tests the battery simulating starting the engine. If ok it is the starter if not replace the battery..good luck.
Apr 09, 2014 | Briggs & Stratton Starter Briggs Stratton...
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
What are the required cranking amps for a briggs and stratton 18hp
if starter turning over slow probably needs taken apart and cleaded or battery not charged enough
Apr 02, 2012 | Briggs & Stratton Garden
Why does my Mower not turn over fast enough to start?
Go to smalleng.com watch video on how to adjust intake and exhaust valves. Call your local repair shop for numbers.
Mar 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Just replaced head gasket, now has to much compression and won`t wind over fast enough to start. have had starter checked and seems ok .10.5 hp briggs and stratton motor in a murray 32 inch ride on lawn...
A head gasket will not greatly increase the compression in a a Briggs motor.
My question is Why did it need a head gasket to begin with?
Will bet it was not running...
A more likely cause if not a fuel problem is to check engine oil if that is good remove the wire from the low oil sensor and see it it will start up for you.
r/
David
Jan 23, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
