Question about Gcv160 Gas Engine
Following fuel leaking through the air filter and exhaust and checking the float bowel & putting the carb back I cannot engage the cord. The break is deploying and was working prior to the fuelleakage
I serviced the mower before use checking the spark plug and replacing the oil and checking the filter. It fired on fourth pull. I cut my back lawn. Now, post fuel problem the blade will not turn although there was some movement initially. I have not tilted the mower the wrong way. I have removed the pull from the mounting and it works fine. I have not hit anything.
  • Vincent Competello
    Vincent Competello Apr 03, 2015
    It's not the end of the mower! If you're handy you can take it apart and fix it for a fraction of the cost of purchasing a new one. A single cylinder rebuild will cost you less than you think!
    Habit-Forming:
    Scholar:
  • 73 Answers
Hi Julie,
Yep, it's me again. Seeing that you were mowing so much tall grass, I'm sure that a good bit of it was still wet. Wet grass builds up under the mower and once dry, becomes hard. If you stopped using the mower long enough for all that grass to dry, there's a chance that the build up of it, is stopping the blade from turning. Have you had a chance to check under there yet?
You can use a putty knife or something like that, to scrape all the dried grass from underneath the mower. Any build up under there, that touches the blade, will slow down or even stop the blade from turning. Just a shot in the dark.
I hope we can figure this thing out pretty soon. I'm running out of ideas! LOL!!! Have a great weekend and good luck. By the way... I'd be happy to come mow your yard for you. I'll wait out on the front porch for you to come pick me up. LOL!
Posted on Apr 05, 2015
  • 1 more comment
  • julie Perry
    julie Perry Apr 05, 2015
    Hi Bill, Yes, me again too!!!! I have managed to move the blade it turns freely now. I was going to try and actually get the blade off but I am a feeble woman and am unable to free the bolt. My husband a couple of years ago had trouble getting if off. Any it moves that is the main thing and as I was turning the blade round oil started to seep out even though I drained the oil or so one thought. i am still unable, however to pull the cord, although I can now pull further. I have been spraying pentrating oil into the spark plug hole just in case the engine has seized but in view of this latest development it looks like it could possibly be something else. I have taken the pull off the machine at it works freely so it is not cross threding. so it maybe something really silly. I think you will be waiting on the porch for sometime especially with our time difference.....LOL!!!!
  • julie Perry
    Success, well, partly! The pull now deploys fully. Tomorrow is "D Day" and I will put some oil back into the machine and spark plug and see what happens. I will mow the lawn until I get another filter but we will see first if it starts. I will let you know. Julie
  • julie Perry
    julie Perry Apr 07, 2015
    Hi Bill, I got it going with a new filter and I was very pleased to say the least. However, I had petrol coming through the air filter again. I turned the petrol off asap and air filter and took the carb off and gave it a really good clean. The flaot in the float bowl was going up and down but not as it should. I got a pin and put it into the hole and got some dirt out. I didn't get the screw and the centre pin out of the carb but water, if you put your finger over the side hole was going through so I assume if water will go through then petrol will definitely. I put it all back together having put a insulating gasket on and bingo it started. I let it run for about three minutes just standing and it idled for a bit and sort of backfired when I first pulled the cord and then it settled. I switched it off but it does appear to be very hot. I will see tomorrow if it is "A" alright and "B" petrol isn't coming throught the filter again. What was obstrucing the cord I have no idea. It could have been something impeding the blade or it could indeed have been petrol in the engine which caused the trouble but either way all is good if I can sort out the heat problem. Thank you so much for your help and support it meant a lot to me as my husband died recently and he always serviced the mower. Thanks again Bill and take care, Julie
    Master:
  • Honda Master
  • 354 Answers
It sounds like the engine may have seized. If you have the plug removed, try to turn the blade itself. If it doesn't move then it makes a seized engine more plausible.
Posted on Apr 03, 2015
Testimonial: "Thanks I had sort of gathered that but thank you for your help."
    Top Expert:
  • Honda Master
  • 45,301 Answers
Remove spark plug and try it if gas blows out you have a carb problem rather sounds like the fuel has leaked and filled the cylinder . means float is sticking in the carb .
Posted on Apr 02, 2015
Testimonial: "I have had petrol where the spark plug is and I have taken the carb off and checked the float. I have now put it all back together but I am unable to deploy the cord to see if it works. I cannot understand why the cord will not deploy post leak."
  • 2 more comments
  • julie Perry
    julie Perry Apr 02, 2015
    If there is fuel in the cylinder will this be the casue of me being unable to deploy the cord?
  • julie Perry
    If the answer is yes how do i get the fuel out of the cylinder?
  • ray gallant Apr 02, 2015
    remove spark plug and pull rope
    also check the rankcase oil it could also be full of gas if it leaked past the rings
It starts full choke ok,put to 1/2 choke run ok, but when l turn choke to off-run position it starts to die and backfires through the muffler.I drain the fuel tank. I drained the fuel bowel,clean the...
It's running lean, Richen up the idle mixture screw or pull the carby of and make sure the passages are not blocked. Also check that there is not a air leak between the carb and head.
Mar 04, 2015 | Garden
Fuel leaking out of carburettor thru air intake valve
try screwing the bolt of the fuuel holderr in the carborator, whhichh is generally used for overflow, screw it tight ,
Apr 15, 2014 | 1996 kawasaki VN 1500 Vulcan Classic
Spitting petrol out side of carb
Your float is stuck or your float needle and seat are not seating well, allowing the fuel height to rise too high which then comes out the side. This is assuming that your float is adjusted properly in the first place. Pull the carb and pull the bowl and check for dirt in the bowel, check the needle and needle seat. check float height. You can also open the bowel drain, before you take anything apart, drain the carb. Turn the fuel on and see if you can flush it out after the bowel has emptied. You can also spray carb cleaner in the fuel inlet on the carb with the drain open and the carb empty. Not really a fix but might get you by for a while.
Mar 07, 2014 | Motorcycles
Mower will not start. Fuel leaking from filter and exhaust
If the fuel is leaking from the air filter or fuel filter for that matter and from the exhaust, this indicates that you either have a valve issue, carb/injector issue, or a combination of both. Do not attempt to start the mower again as it is not only harmful to the engine, but could result in injury or even death to you.
This sounds at first thought, as if it may be a float problem, fuel is backing up somewhere inside the engine and therefore leaking out where it can. First logical step would be to take the carb off, clean out the dirt/debris and make sure your float moves freely and isn't being obstructed, clean up excess fuel, reinstall the carb, and with proper emergency equipment (fire extinguishers for gasoline based fires) attempt to start the mower.
Sep 28, 2013 | Garden
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Gas is leaking out when the generators is running. What should I do to fix it?
where the -tank, lines ,fuel ****? , o ring between carb body and bowel? is it running ok? if not and fuel is coming out of carb than your float and needle is stuck by gummy deposits. you will have to remove float bowel and gently pull down on float ,a good carb cleaning is in order ,might as well check main jet and others for blockage.SHUT OFF FUEL AND KEEP FUEL VAPORS AWAY FROM IGNITION SOURCES do not run it if you have a leak.
Feb 01, 2011 | Electrical Supplies
Mower problems
Its a fuel flow problem, start with checking the in line fuel filter,if thats clean and the gas is flowing well, then its probably some dirt or water in the carb. The carb has a brass nozzle in the middle of the float area. remove the carb, hold it upside down and remove the bowl, use a flat screwdriver and unscrew the part thets recessed in the part thet sticks up thru the float, clean the tiny little holes with a torch tip cleaner set, (available at any auto supply store for about 3 dollars). then spray some carb cleaner thru the part and the dry it with air and reassemble. This should solve your problem
Nov 01, 2009 | Garden
Change fuel filter it sounds like it's not getting gas.
Remove your bowel on your carb with a 1/2 in wrench clean and check your movement of the float,use some copressed air to make sure do dirt is left install bowel ,I hope this helps you
Oct 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Gcv160 Gas Engine Logo
89 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
