Question about Eltax Audio Players & Recorders
I have a replacement tweeter for an Eltax Liberty 5+ floorstanding speaker. I have removed the screws that hold the old tweet in place but can't seem to remove it? Any tips please?
    Sergeant:
  • 192 Answers
Hi, The hole that was cut for the tweeter is holding the magnet. It was tight going in. And hard to get out. Take a flat screwdriver and pry up one of the edges a little. Then go to opposite side and pry up a little bit. You may need to put something in the gap of the first side you pry up so it doesn't go back in. Once you have both sides up a little bit. You should be able to grab ahold of it with your fingers and remove it. May have to move it back and forth .
Posted on Apr 03, 2015
Looking for a replacement tweeter 5DR/53361?
there are plenty of electronic retailers who sell speakers
try e-bay using those specs in the search box
Mar 03, 2016 | Mirage OMD-15 Floorstanding Speaker Black...
It sounds like we blew the tweetter part of speaker, when we opened it up it looks like the tweetter is solid and will not come out
Check the tweeter with ohm meter.
There should be screws holding tweeter in place. Touch around the edge of the tweeter for soft area. Screws may be below lable ring which is glued on.
Feb 07, 2015 | Audio Players & Recorders
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
How to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
Hello there i have a mackie srm 450 speaker system and im not getting any high end tweeter sounds just bass only what coule be the problem manay thanks Paulie
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Aug 12, 2010 | Mackie SRM-450 System
Mission 753 spares / tweeters hi can you help me please ? my tweeters from my mission 753 floorstanding speakers have blown.. been in contact with mission, and have been told that they no longer have...
Hi Ricky...saw your post re the 753 Mission tweeters. Your post goes back some months ago but I wondered if you got fixed up with replacement ones or a workaround ??
Regards
Wayne
urban494@hotmail.com
Jan 29, 2010 | Audio Players & Recorders
No sound from top speaker
Yes Eltax will sell you a replacement part. THey also sell the woofer/driver as well. Changing either is simple. You will need a Torx screwdriver to unattatch the driver from the box. Then just pull it out, and attatch the connectors to the new tweeter. Make sure you get the wiring right for polarity. Ie look at the writing on the back of the tweeter and keep the wires going to the same connections on the new one. Screw it back in...and you are done. I have a pair of these as well, and have just done the same replacing both woofers that had been pushed in my my niece and her inquisitive hands !
May 17, 2009 | Eltax Liberty 5+ Main / Stereo Speaker
Eltax millenium 500 speaker problem
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Apr 16, 2009 | Eltax Millennium 500 Speaker
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Removing Driver from Sealed Cab
1. Remove the front cover.
2. Remove the four bushes that held it in place. Beneath them are crosshead screws.
3. Remove these screws, and the surround board they hold.
4. You can now see the bass speaker retaining screws. remove them and withdraw the speaker *carefully*. (A knife under the edge helps to get it going.) The wires are at the back mixed up with the damping wool.
5. The tweeter has its retaining screws under the rubber gasket stuck to it.
6. The connectors shoud slide off the lugs, but mine are pretty stiff. Careful with the tweeter's: mine pulled out the termnal completely, and I've had to replace the unit!
Nov 21, 2007 | Mission 780 Main / Stereo Speaker
104 people viewed this question
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
